o2x7 need help Phone was fine before flashing and new one in box, and after flashing phone is unlocked but 4 leds around navy butons flashing non-stop even after lcd light goes down and I also noticed that camera not working, meaning only white screen showing and nothing more. I backup flash before flashing and I'll send to Infinity support. wbr. |
Hi, Pls, send your backup to [email protected] also, we have 2 unlocked flash files in support ara. Try to flash both and test phone. Waiting for you results. |
1 Attachment(s) I send you flash and I'll try what you will help me, but I'll post result tomorow here. wbr. |
I also have same probleme,and i also have meake a backup-i have use only this file to flash o2x7_Main_SP710_17.04.04_DE_Prepaid_En_De_Unlock.4 7M.bin for flash. can be the phone repaired with other flash file from support page, or should i sent the backup file to infinity team??? |
Hi, Please, if you have some free time, send backup to [email protected] We have now 3 unlocked flash files in support ara. Try to flash other files and test phone. |
YES, problem is solved with one of those two new flashes from support are. Thanks infinity support. wbr. |
with which date in support area 21.02.02 22.01.01 17.04.04 please answer |
Any of files with word "unlock" at end of file name. Different flash files exist because several different hardware configurations exist for O2X7. |
wbr. |
works in also in my case i try second time with flish file from 21.02.02 and works ok |
hi i could not see the flash file in the support area is it under Benq? please tell me now Sorry i have seen it |
Hi! I have problem with unlocking o2x7 See te log: COM8 selected Device: O2X7 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 460800 Set baud Done Check Flash... Flash ID1: 00B000B1 Flash ID2: 00B000B0 Check Flash Done Check space... In progress [eeprom-2]... File saved: Backup_eeprom-2_2007-4-16_18-24-4.47E.bin Err: unknown firmware Check space Fail Finished Remove/Install battery now ! Time used: 32 sec How can I unlok this version? I made full backup. Should I sent it to Infinty team for test? |
Hi, 1. send flash backup to [email protected] 2. try to flash phone with different frmware from support area and see results. I think that phone will be working and unlocked with flash files from support area. |
