Old 04-20-2006, 14:27   #1 (permalink)
Member: 67805
Thanks Meter: 343
o2x7 need help
Phone was fine before flashing and new one in box, and after flashing phone is unlocked but 4 leds around navy butons flashing non-stop even after lcd light goes down and I also noticed that camera not working, meaning only white screen showing and nothing more.
I backup flash before flashing and I'll send to Infinity support.
wbr.
Old 04-20-2006, 14:40   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,456
Hi,
Pls, send your backup to [email protected]
also, we have 2 unlocked flash files in support ara. Try to flash both and test phone.
Waiting for you results.
Old 04-20-2006, 14:53   #3 (permalink)
Member: 67805
Thanks Meter: 343
I send you flash and I'll try what you will help me, but I'll post result tomorow here.
wbr.
Old 04-21-2006, 17:09   #4 (permalink)
crisrad's Avatar
Member: 98823
Sonork: 100.78833
Thanks Meter: 9
I also have same probleme,and i also have meake a backup-i have use only this file to flash o2x7_Main_SP710_17.04.04_DE_Prepaid_En_De_Unlock.4 7M.bin for flash. can be the phone repaired with other flash file from support page, or should i sent the backup file to infinity team???
Old 04-21-2006, 19:10   #5 (permalink)
Member: 130995
Hi,
Please, if you have some free time, send backup to [email protected]
We have now 3 unlocked flash files in support ara. Try to flash other files and test phone.
Old 04-21-2006, 19:10   #6 (permalink)
Member: 67805
Thanks Meter: 343
YES, problem is solved with one of those two new flashes from support are.
Thanks infinity support.
wbr.
Old 04-26-2006, 10:47   #7 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 481
wbr.
which from the flashe s exactly can unlock this phone
with which date in support area
21.02.02
22.01.01
17.04.04
please answer
Old 04-26-2006, 12:24   #8 (permalink)
Member: 130995
21.02.02
22.01.01
17.04.04
please answer
Hi,
Any of files with word "unlock" at end of file name.
Different flash files exist because several different hardware configurations exist for O2X7.
Old 04-26-2006, 16:56   #9 (permalink)
Member: 67805
Thanks Meter: 343
21.02.02
22.01.01
17.04.04
please answer
In my case it was 22.01.01
wbr.
Old 04-26-2006, 22:13   #10 (permalink)
crisrad's Avatar
Member: 98823
Sonork: 100.78833
Thanks Meter: 9
works in also in my case i try second time with flish file from 21.02.02 and works ok
Old 04-28-2006, 14:00   #11 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
hi i could not see the flash file in the support area is it under Benq? please tell me now
Sorry i have seen it
Old 04-16-2007, 17:00   #12 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 72
Hi! I have problem with unlocking o2x7
See te log:
COM8 selected
Device: O2X7
Checking data, wait...
Action: Unlock
Boot...
Connecting, wait...
Release Power button now !
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Flash ID1: 00B000B1
Flash ID2: 00B000B0
Check Flash Done
Check space...
In progress [eeprom-2]...
File saved: Backup_eeprom-2_2007-4-16_18-24-4.47E.bin
Err: unknown firmware
Check space Fail
Finished
Remove/Install battery now !
Time used: 32 sec
How can I unlok this version? I made full backup. Should I sent it to Infinty team for test?
Old 04-16-2007, 19:16   #13 (permalink)
Member: 130995
Hi,
1. send flash backup to [email protected]
2. try to flash phone with different frmware from support area and see results. I think that phone will be working and unlocked with flash files from support area.
need help master manole n95-8gb write screen restart haslyn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-30-2010 10:56
2700 flashing need help ngaia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 11:48
nokia masters need help.............. ANILMPLY Nokia Hardware & Hardware Repair 0 03-29-2010 10:48
O2x7 Need Help PIRATOSS Infinity-Box 1 09-25-2007 18:28
Page generated in 0.34675 seconds with 9 queries
