03-13-2006, 13:07 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: IN YOUR DREAMS Age: 41
Member: 74749 Status: Offline Thanks Meter: 167 | o2xlib dead after flash y??? plz help Loading... O2X1i_Main_v110.37M.bin Loaded Loading... O2X1i_LP_v110_En_De.37P.bin Loaded Loading... O2X1i_repair_eeprom_01.37E.bin Loaded COM1 selected Device: O2X1i,O2XLI Checking data, wait... Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0089:8855 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Write: Flex Write: Language Pack Writing Done Finished Remove/Install battery now ! Time used: 679 sec COM1 selected Device: O2X1i,O2XLI Checking data, wait... Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0089:8855 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Eeprom Writing Done Finished Remove/Install battery now ! Time used: 108 sec this is flashing log thankx falak |
03-13-2006, 13:27 | #2 (permalink) | |
as i can understand, now phone can be flashed again but can't power-on. Is it true ? pls, double check battery, is it enough charged. also, pls, give me full info from phone back label. | |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
