05-21-2018, 09:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Online Thanks Meter: 1,640 | Oale X1 not done Code: Card found : S/N : 5C203D37 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 87 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : F40122426977696E20103237313664AF [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xF4 , OEM : 0122 [eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi [eMMC] : FLASH_CID : F40122426977696E20103237313664AF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0x2476092548B8EF567051382471CB8007 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : full_gxq6580_weg_l ProdModel : gxq6580_weg_l Device : gxq6580_weg_l AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P6_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : sp2509_mipi_raw CAM [1] : sp2509main_mipi_raw CAM [2] : gc2365mipi_raw CAM [3] : gc2365main_mipi_raw CAM [4] : mn045_mipi_raw CAM [5] : imx219_mipi_raw CAM [6] : gc5005mipi_raw CAM [7] : gc5005main_mipi_raw CAM [8] : ov5693_mipi_raw CAM [9] : sp540a_mipi_raw CAM [10] : imx149_mipi_raw CAM [11] : hm5040_mipi_raw CAM [12] : ov5675_mipi_raw CAM [13] : hm8040_mipi_raw CAM [14] : gc5024_mipi_raw CAM [15] : gc8024mipi_raw CAM [16] : gc5024_sub_mipi_raw CAM [17] : ov5675_sub_mipi_raw CAM [18] : gc2375mipi_raw CAM [19] : bf2206main_mipi_raw CAM [20] : bf2206mipi_raw CAM [21] : ov8856_mipi_raw CAM [22] : hi256main_mipi_yuv CAM [23] : hi256_mipi_yuv CAM [24] : ov509_mipi_raw CAM [25] : a5142_mipi_raw CAM [26] : s5k4h8_mipi_raw#ov9762_main_mipi_raw CAM [27] : ov9762_mipi_raw CAM [28] : gc2355_mipi_raw CAM [29] : gc2355main_mipi_raw CAM [30] : gc5024_mipi_raw imx219_mipi_raw hi259_mipi_raw hi259_sub_mipi_raw hi553_mipi_raw gc2365mipi_raw gc5005mipi_raw ov9760_mipi_raw rs9760_sub_mipi_raw gc2365main_mipi_raw mn045_mipi_raw sp2509_mipi_raw sp2509main_mipi_raw ov5693_mipi_raw s5k5e2ya_mipi_raw gc8024mipi_raw sp540a_mipi_raw CAM [31] : imx179_mipi_raw CAM [32] : ov5670_mipi_raw CAM [33] : sp1628_yuv gc2755_mipi_raw imx166_mipi_raw sp2508_mipi_raw MODEM : Z6U090_band_1_2_5_8 LOCALE : K_PRODUCT_LOCALES =th_TH en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES my_ZG lo_LA Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 87 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : F40122426977696E20103237313664AF [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xF4 , OEM : 0122 [eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi [eMMC] : FLASH_CID : F40122426977696E20103237313664AF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0x2476092548B8EF567051382471CB8007 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P6_1_wg_n Read Error , NVRAM area is blank or damaged Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! |
05-21-2018, 14:13 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SW found NVRAM is blank. Probably it damaged and just NVdata alive. Make MODEM RE-init and repeat NVRAM reading. |
