09-05-2018, 09:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | How to format spd cpu6533g In that condition ,,,how to connect set ? |
09-05-2018, 09:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 301 | 1) SPD if it is spd then power off set remove battery insert usb cable and hold "0" button and insert battery 2) RDA and if it is reda then power off set while battery is inserted connect usb cable when it shows charing icon then press "0" button and keep holding it until it detects if set is is not connecting then check drivers in device manager that it |
The Following User Says Thank You to Ismail khan1978 For This Useful Post: |
09-05-2018, 10:23 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Power of the device connect usb when show charging symbol press 0 and do ur desire operation | |
The Following User Says Thank You to princesaddam For This Useful Post: |
