05-02-2018, 19:17 | #31 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1422878 Status: Offline Thanks Meter: 164 | Basic Demo Dobel click in the name of file and it will rename to MTK_AllInOne_DA_SP.bin and put into \InfinityBox\CM2MTK\Boot folder Download http://forum.gsmhosting.com/vbb/atta...1&d=1525288551 BR Helpinterchange |
The Following 4 Users Say Thank You to helpinterchange For This Useful Post: |
05-02-2018, 19:42 | #32 (permalink) |
Member: 1422878 Status: Offline Thanks Meter: 164 | Demo 2 with Folcer access This a Basic demo with Folcer access Doble click in the folder, only will show .bin files, then doble click in the name of file and it will rename to MTK_AllInOne_DA_SP.bin and put into \InfinityBox\CM2MTK\Boot folder |
The Following 2 Users Say Thank You to helpinterchange For This Useful Post: |
05-03-2018, 00:20 | #33 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Sông cầu phú yên vi̓
Member: 1543081 Status: Offline Sonork: 0011 Thanks Meter: 47 | Quote:
Gửi từ SM-G610F của tôi bằng cách sử dụng Tapatalk | |
The Following User Says Thank You to luomnguyen For This Useful Post: |
05-03-2018, 04:19 | #34 (permalink) |
Member: 1543081 Status: Offline Sonork: 0011 Thanks Meter: 47 | WHAT IS NEWS?? - FIX SOME BUG. - ADD Brand: ... list of folders ... Model: ... list of folders ... DA: ... list of files ... ... LINK:https://drive.google.com/file/d/1Jnq...ew?usp=sharing |
The Following 10 Users Say Thank You to luomnguyen For This Useful Post: |
05-03-2018, 04:47 | #35 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote:
oppo F3 files restore but not working Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! | |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
05-03-2018, 14:04 | #39 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | Quote:
The Following 2 Users Say Thank You to daryl007 For This Useful Post: |
05-03-2018, 15:17 | #40 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Eswatini
Member: 483137 Status: Offline Thanks Meter: 32 | suggestion from me would be for infinity team to make add on, that will add a new tab on current infinity CM2 1.58 - to allow you to select DA (Browse to Location) - and Create/save like in infinity best user.ini, using this ini CM2 can then redirect when selected user.ini which DA to use(name must not be specific to MTK_AllInOne_DA_SP. User can add "Brand, Model to user.ini After save ini, the models can show in SP Model Select, using the names used in the ini creation tab. Last edited by Andy Exalto; 05-03-2018 at 15:25. |
The Following 2 Users Say Thank You to Andy Exalto For This Useful Post: |
05-03-2018, 15:55 | #41 (permalink) |
Member: 483137 Status: Offline Thanks Meter: 32 | @luomnguyen Thank you You are a saviour now, no need for complications! easy to use, please add auto load on start up, and change "load" button to "refresh" for people that will add new DA files while software is open. Sorry for correction on "Restore" Button error on spelling. |
The Following 3 Users Say Thank You to Andy Exalto For This Useful Post: |
05-03-2018, 16:18 | #42 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | @luomnguyen,Addon Needs reduce Size & fonts to be same as Cm2 modules. I Also request add MTK 1.58 BUTTON Otherwise thanks for your work. |
The Following 2 Users Say Thank You to Kirumira For This Useful Post: |
05-04-2018, 09:31 | #45 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | And not only add many models DA need to add custom choise (custom DA select) if possible |
The Following User Says Thank You to rebainoor For This Useful Post: |
