Old 06-04-2018, 12:30   #121 (permalink)
shaikhmobiles's Avatar
Member: 551708
Thanks Meter: 39
Originally Posted by mubarak2344 View Post
k, i had founded solution for u...
will do it in my next version with all user suggestions . the final version with installer.....
May b tomorrow or the next day.
when i set manual boot it give me this error..... Plz help me...
[DA_ERROR] : Correct BOOT CONFIGURATION not found for target!
Try Re-Install CM2MTK module!
Boot Error!
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with CERT
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:03
Reconnect Power/Cable!
Old 06-04-2018, 20:49   #122 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 573
Boot Error!
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:03
Wrong DA selected ,,,,
Pls mention brand and model....
Thank u....
The Following 2 Users Say Thank You to mubarak2344 For This Useful Post:
Old 06-05-2018, 00:08   #123 (permalink)
Member: 551708
Thanks Meter: 39
Thank u....
I am testing on nokia 3 and qmobil i6 2017
Old 06-05-2018, 10:09   #124 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 573
Use CM2 DA files , DA from other tools may not work with cm2.....
The Following User Says Thank You to mubarak2344 For This Useful Post:
Old 06-05-2018, 10:14   #125 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,933
Yeah, lolcano and other da files are encrypted. Those types support, probably, will be enabled later just for fun.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-05-2018, 10:46   #126 (permalink)
Member: 5926
Thanks Meter: 266
Originally Posted by luomnguyen View Post
WHAT IS NEWS??
- FIX SOME BUG.
- ADD
Brand: ... list of folders ...
Model: ... list of folders ...
DA: ... list of files ...
LINK:https://drive.google.com/file/d/1Jnq...ew?usp=sharing
RESTRONE ?, what is "restrone" ?
Old 06-05-2018, 10:48   #127 (permalink)
Member: 5926
Thanks Meter: 266
Oh, I saw you finaly corrected
Lets see what comes of this.
Old 06-06-2018, 10:44   #128 (permalink)
Member: 148515
Thanks Meter: 15,693
This is not bug....
Its user fault, we can make software for default location only
Infinity Installer write actual software module location to Windows registry during installation.
[HKEY_CURRENT_USER\Software\InfinityBox\CM2MT2]
"Install_Dir"="c:\\InfinityBox\\CM2MT2"
So it's possible to read this value from registry and set working path for your software.
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 06-06-2018, 10:49   #129 (permalink)
Member: 148515
Originally Posted by asimali3 View Post
this is just begining i m also working on it .. i hope i will be the part of infinity team
We will be glad to see your results!
Old 06-06-2018, 10:50   #130 (permalink)
Member: 148515
please post here your Infinity S/N
Old 06-06-2018, 11:08   #131 (permalink)
Member: 148515
@luomnguyen
check other separate thread
Old 06-07-2018, 11:26   #132 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 573
=== DongleManager [Infinity] v1.72 [07-06-2018 14:54:05] ===
Searching...
Box/Dongle found: [BEST]
Serial No (S/N): EFAE978C
Firmware version: 0122.02
"UK Edition" status: Off
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle v.0136
- 03: [BEST] v.0122
- 07: #7
Old 06-11-2018, 00:14   #133 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 573
Manual Boot Addon V4 For CM2MTK V1.58 BY MUBARAK
Manual Boot Function For secured devices !
- Main
Manual DA Selection and set boot function.
Auto Restore Original Old DA Without Backup(For Plug and Play).
Auto Restore Original Old DA When Addon Close.
Launch CM2MTK V1.58 via Addon.
Launch Infinity IOS LOGIN Via Addon.
- Others
Visible User Interface
Show Success Logs with progess bar.
Show Error Logs
- Tested Os
All Type of Windows Os(32 and 62 BIT)
- Fixed
Some Minor Bugs.
Fixed Log overlapping.
Now Addon will also work on users who had installed CM2 in Different Drive.
Thanks to Infinity Team For Giving Me This Opportunity.
@Users,
Report me if u found any bugs or suggest me to add anything else.......
Download Link :
MANUAL BOOT ADDON V4 BY MUBARAK
Note:
Extract Rar File Into "InfinityBox/CM2MTK/" Folder And Run The Apllication........
Thank You Supporters.....
The Following 21 Users Say Thank You to mubarak2344 For This Useful Post:
Old 06-11-2018, 00:20   #134 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 573
Originally Posted by rebainoor View Post
I changed default instalation to D:/ drive to take all my backup files in safe drive not in system drive because if I have a probleme with system in C/: drive not need to find all my backup files in faulty partition
not only infinity box soft changed to D/: drive but all my boxs software
Bro Pls check now V4 , it will work on differnt drives....
Thank U....
Old 06-16-2018, 14:48   #135 (permalink)
Member: 1043909
Thanks Meter: 52,095
Searching...
=> Activations:
- 03: [BEST] v.0122
- 07: #7
Thank you for your efforts !
+1 year support done for your card.
Let's hope we will see here more user's reports and news.
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Page generated in 0.41106 seconds with 8 queries
