08-15-2009, 14:30 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420862 Status: Offline Thanks Meter: 51 | Old method for CALIBRATION is better than the one in new update i just formatted one S4 which had calibration problem when i try to calibrate in new Chinese miracle update it says read full flash and then it will calibrate , i did try this method on one handset but it is so much time consuming that it took 4730sec to read then i try in the old exe handset was calibrated in 3rd try within 5min . So how do we solve this problem . COM7 selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5F03:0006 status: FF boot packet size: 0400 Release Power button now ! The middle part of log was too big so i just skip detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: JRDSZ25_07B_GEMINI_PCB01_GPRS_MT6225_S00.GH57P4_ME _JX02_09_0313_10__fullflash... detected record size adjusted detected record size adjusted detected record size adjusted detected record size adjusted detected record size adjusted detected record size adjusted detected record size adjusted detected record size adjusted file saved: E:\Program Files\InfinityBox\ChineseMiracle\JRDSZ25_07B_GEMIN I_PCB01_GPRS_MT6225_S00.GH57P4_ME_JX02_09_0313_10_ _fullflash_20090810-203448.B0M.bin file saved: E:\Program Files\InfinityBox\ChineseMiracle\backup_security\J RDSZ25_07B_GEMINI_PCB01_GPRS_MT6225_S00.GH57P4_ME_ JX02_09_0313_10__system_log_C1BD9F34_AAFC5337_2009 0810-203502.B0X.bin Finished, time used:4730 sec Remove/Install battery now ! COM7 [VCP8] selected module v2.82 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3203:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S4_TOSHIBA_EFIAPVRHMIT_V038 Version: A760_V3.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 1357902xxxxxxx warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 done 209 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 13 sec Remove/Install battery now ! |
08-15-2009, 19:07 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | on one mobile i had try with all ver but all faild then i try to cal. with new method its rocks no problem how much time its takes we need work !! Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
08-15-2009, 19:24 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! use 460800 speed for fast flash reading! if you wish, you can still use old version of CM with calibration via test mode |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
08-15-2009, 19:55 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | today I have tried to celibrate with latelst update 2.89 ser fw : CKT25_06B_DINOSAUR5_CK_PCB01_GPRS_MT6225_S00.DINOS AUR5_BXD_L4EN_202_080312_LCD_SET0_SS75_CTF_BT__ful lflash_20090815-171640.B0M but when I do it with method 2 then calibrat ok but display light gone and when I do it with method 1 then light ok but still stuck on celibration !!!!!!!!!!!!!!!!! I have also do complete format , safe format and all possible way but not done successfully !!?? |
08-15-2009, 20:11 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
restore full flash backup and then new calibration with latest ChineseMiracle software. | |
08-18-2009, 05:18 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 45
Member: 4021 Status: Offline Thanks Meter: 782 | i hope that the old method of calibration will be added again.. it was much easier than this latest update... coz reading of files will take time.. not like before with just some clicks and viola!!! thanks! |
08-18-2009, 19:06 | #14 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | better keep both option on chinese miracle only calibrating touch without backup full flash and the new one ... back up full flash then calebrate ... user will choose which one they like ... |
08-18-2009, 19:45 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello guys! backup on fastest speed take some minutes. you will loose more time on each method of calibration via test mode. |
Some sugesstion for mx-key to make it better than the best:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 06-12-2009 02:44 |
Older Version Works Better Than The Latest | chowdary | NSPRO | 0 | 01-31-2006 19:31 |
Need V186 Firmware newer than the one in the support | cubafreak | Smart-Clip | 1 | 12-27-2005 15:14 |
Windls 2.3 is better than JIC (neelix)!!!!!!!!!! | bluelights | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-19-2002 01:08 |
Windls 2.3 is better than JIC (neelix)!!!!!!!!!! | bluelights | Main Sales Section | 2 | 01-19-2002 01:08 |
