03-05-2007, 22:39 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200321 Status: Offline Thanks Meter: 2 | One Question! V170... I have the Infinity Box, have one week with this box, but, i can't unlock nothing, that it does, but i need a little help... Firts. The lights front in the box, none power on...is normal this? Second. How to unloked for Motorola V170? Thanks for you help.! I want to learn...! |
03-05-2007, 23:02 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Box LEDs etc: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 V170: what is the probem exactly ? |
03-05-2007, 23:18 | #3 (permalink) |
Member: 200321 Status: Offline Thanks Meter: 2 | Hi, thanks for you answer, but this is the problem, the Leds for front box none on...i do this...UP= F-Bus, USB out used, but Rx/Tx leds no power on..none. i want solution this problem firts...thanks for you help. |
03-06-2007, 10:06 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, go to Device Manager and see Ports. Disconnect box from PC. If you see that there is no COM10 after you disconnect box this means that COM10 is correct com port. |
03-06-2007, 19:44 | #7 (permalink) |
Member: 200321 Status: Offline Thanks Meter: 2 | Hi, i do this, and yes, my com port is correct, but, the problem persist...the leds none on...well, when put in the cable G50 inside in com1 the led RTS on, the light is blue, is good signal? But i can´t read flash of the fone, is a V170... Can you help me, please... |
03-06-2007, 20:19 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, it looks like that you ignored my link with box description, in other case you did not talk about RTS LED. Connect cable with "X60" mark (hands-free cable with THREE metal pins) to box LEFT RJ-45. Connect cable to phone. Try to make required operation. Also, what is phone firmware version ? (press #02#* to see it) it can be that you need to use method like this: http://forum.gsmhosting.com/vbb/showthread.php?t=334357 p.s. please, don't ignore my links and read it very carefully. Beleive me, a lot of useful info there. |
03-07-2007, 00:43 | #11 (permalink) |
Member: 200321 Status: Offline Thanks Meter: 2 | Hi, i understand little, thanks...but i have one question more.. Where take a more pictures for futures "test point"...and the flashes where is? i looked but i canīt found... Thanks for you help.. |
One Question About Cruiser,pls | Gubby_J | Cruiser Suite | 2 | 03-29-2010 12:46 |
Only one question for Emmifull box. | Pandemonio100 | Motorola Old Legacy (EMMI) | 6 | 08-02-2001 21:37 |
One Question on the Moderators! | Meam | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-19-2001 17:30 |
One question for Dejan's Flsher GURU | Tigy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 01-18-2001 09:03 |
