08-31-2009, 13:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Only english After format ==== log: [28/08/2009 18:33:43] ==== COM3 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0203:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: TL_T819Z_P31U00F07L70_01_16.BIN ver. sw 2: TL_T819Z_P31U00F07L70_01.16, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: TL_T819Z_P31U00F07L70_01_16__ffs... file saved: C:\Arquivos de programas\InfinityBox\ChineseMiracle\TL_T819Z_P31U 00F07L70_01_16__ffs_20090828-183532.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98004900000002:18E59F00000000 Finalization Done Finished, time used: 172 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-31-2009, 14:21 | #2 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | i flash my backup portugues and others language is ok but after new format safe mode sonly english: COM3 [VCP1] selected module v2.91 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0203:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: TL_T819Z_P31U00F07L70_01.16 Version: PX detecting structure #2... 5 11 done 67 byte(s) read imei: 35656302002204 connection Ok building list... done items to clear: 169 warning: wrong packet cs warning: wrong packet cs items cleared: 169 of 169 building list... done items remains: 0 Finished, time used: 22 sec Remove/Install battery now ! Help me |
09-02-2009, 11:12 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! the only possible way is following: make original backup of eeprom. then do format FFS selected items. each time select for formating different items and check if they will affect on language settings. resotre backup and continue search if they reset. this way at the end you can find just 1 item which is in charge for language in this phone. exclude it from reset and you will get totaly clear phone with all languages. this is quite long procedure, but you can make it if this is very neccecerry |
w205 only English after flashing LP | _zer0_ | Sony Ericsson | 0 | 01-20-2010 23:40 |
F305 only english after flash | daffy duck | SETool2 | 2 | 09-17-2009 15:01 |
TV N95 Only English Language after format and After Falash | Tracer Gsm | Chinese Models & Cloned Phones | 1 | 02-04-2009 21:36 |
Plz Help >>> China Q559 Only Blinks after Format | zeel_zeel | Infinity-Box | 4 | 12-04-2008 07:02 |
T190 After Unlock Only English Language? | gsmdeli | Motorola ODM | 3 | 12-12-2002 06:57 |
