03-27-2018, 11:14 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 894846 Status: Offline Sonork: ajmal Thanks Meter: 111 | onyx-3s lte frp secure boot Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
03-27-2018, 11:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello @ ajmal_khan713,Read something download da file from ios support area post success logs here Read link : http://forum.gsmhosting.com/vbb/f296.../#post12989320 Good Luck |
The Following User Says Thank You to gracy_elec For This Useful Post: |
03-27-2018, 12:29 | #5 (permalink) |
Member: 894846 Status: Offline Sonork: ajmal Thanks Meter: 111 | ait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 44000145313034468E390136358412B2 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Finish at : [3/27/2018 / 1:48:33 PM] |
03-27-2018, 14:07 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Still same can't be, because phone must properly conenct without hold keys in preloader mode. Power it on. Insert cable. Power it off. When device starts power off - press operation button. |
