03-28-2017, 20:08 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | htc desire d516w dead help please .. Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : htc Device Manufact.: HTC Device Model : htc_v2_dug Device CPU : MSM8610 Device IntName : htc_asia_india Device Version : 4.3 CU_SWVer : HTC Device Compile : 8/14/2014 4:12:59 PM Device ExtInfo : HTC Desire 516 dual sim Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 02D4CD10 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 956F05F15CCAF7F2AD8272539CE76F5F ID_BLOCK_L : 8FC648E3D47FEF64995439F6FC332D2E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 18 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : NON-HLOS.bin Flashing : boot.img Flashing : system.img ProgStart : start 742128, num 3344 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 02D4CD10 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 956F05F15CCAF7F2AD8272539CE76F5F ID_BLOCK_L : 8FC648E3D47FEF64995439F6FC332D2E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 18 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : NON-HLOS.bin Flashing : boot.img Flashing : system.img ProgStart : start 742128, num 3344 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 02D4CD10 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 956F05F15CCAF7F2AD8272539CE76F5F ID_BLOCK_L : 8FC648E3D47FEF64995439F6FC332D2E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 18 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : NON-HLOS.bin Flashing : boot.img Flashing : system.img ProgStart : start 742128, num 3344 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : htc Device Manufact.: HTC Device Model : htc_v2_dug Device CPU : MSM8610 Device IntName : htc_asia_india Device Version : 4.3 CU_SWVer : HTC Device Compile : 8/14/2014 4:12:59 PM Device ExtInfo : HTC Desire 516 dual sim Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Enabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 02D4CD10 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 956F05F15CCAF7F2AD8272539CE76F5F ID_BLOCK_L : 8FC648E3D47FEF64995439F6FC332D2E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 18 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : NON-HLOS.bin Flashing : boot.img Flashing : system.img ProgStart : start 742128, num 3344 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
03-28-2017, 21:55 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Make eMMC test. Open Memory Tool, press right mouse button. Select eMMC test. You can flash separati files via it also, it allow you skip all files before problematic one and allow try flash it. If error will be at same place - it is HW 99%. |
