Old 03-28-2017, 02:28   #1 (permalink)
Member: 2636288
open and edit .ispff
Hello! How can I open and edit the fullflash backup .ispff file?
I need to flash saved full backup to another same device but CM-2 says file is bigger than device memory. In any case, flash it?
From log:
ISPFF ID : novo , TARGET ID : 6580
BBID missmatch! Stop killing phone!!!
Select CORRECT file for that phone!
Old 03-28-2017, 04:54   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
From log:
Read Scatter firmware again from same working phone,will help than ISPFF DUMP
NO Dump EDITING required
Old 03-28-2017, 06:46   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Or rename it to MT6580_MODEL_NAME.ispff
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 03-28-2017, 15:22   #4 (permalink)
Member: 2636288
Kirumira,
Working phone no longer.
JayDi,
I will try it.
Old 03-28-2017, 16:39   #5 (permalink)
Member: 2636288
JayDi,
Thank you! Everything worked out! But the new phone is a bit different, the touch works incorrectly, as in the mirror. Can it be fixed?
Old 03-28-2017, 16:59   #6 (permalink)
JayDi's Avatar
Member: 462970
Seems as device have Dynamic HW settings ( TP or ITEMS ) , or it embded in LK/Boot/Preloader.
Readout FW, instead of dump, find similar phone or FW and try change those files and reflash phone.
Old 03-28-2017, 17:04   #7 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
JayDi,
Now,Post here Read Info logs anybody with Correct Firmware will help you.
Old 03-28-2017, 23:44   #8 (permalink)
Member: 2636288
Forum do not give me post or upload .txt file. Says An error has occurred! You must have 10 posts in order to post links.
Old 03-29-2017, 00:04   #9 (permalink)
Member: 2636288
My phone info here. Remove the blanks.
goo. gl / RKPknn
Page generated in 0.18254 seconds with 8 queries
