Old 06-25-2016, 07:19   #1 (permalink)
Member: 621121
Thanks Meter: 340
Oppo 1201 EMICFG_NOT_FOUND
phone not connect without pressing V+ key
Operation : Check / Read Info [ v1.51 ]
Wait for phone...
Phone found! [ 72 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 150100463331324D4206CCBFC64D33C9
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00.00.09
Reconnect Power/Cable!
Old 06-25-2016, 07:34   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,289
Replace or Charge your battery,Read again.
If the same INIT PRELOADER.
Old 06-25-2016, 08:10   #3 (permalink)
Member: 621121
Thanks Meter: 340
@Kirumira
Working and new phone with 80% charged
Trying to read firmware
Old 06-27-2016, 11:19   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,113
connectivity issue or
seems like emmc or other hardware
Old 07-05-2016, 10:42   #5 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 419
Not working for me I charged battery 90% but not working same as above logs.
Old 04-15-2019, 13:28   #6 (permalink)
Member: 2762776
Thanks Meter: 15
Select firmware in flashing section and try works 100 %
Page generated in 0.20821 seconds with 7 queries
