Old 11-07-2015, 11:33   #1 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,731
oppo A11w : DA init Failed! Error code : 0x5
i want to backup this phone
model: oppo A11w
Operation : Check / Read Info [ v1.36 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : FE014E50314A39344C126841197522DB
DA Stat : v4.2 on BBID : 0x87
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00BC
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:06
Reconnect Power/Cable!
Old 11-07-2015, 11:38   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,001
Need connect without holding BootKeys.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-07-2015, 12:04   #3 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 728
my same problem solved after initialize preloader using v 1.33 new version give same error ..may be something new in new version
help without pressing key phone not detect.. if press key Error code : 0x5
Old 11-07-2015, 13:28   #4 (permalink)
JayDi's Avatar
Member: 462970
We regular update InitDB for MTK SP phones, but it not a complete way. Some phone require init preloader in any case for correct work.
Page generated in 0.17751 seconds with 7 queries
