Old 01-24-2017, 10:03   #1 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Oppo A1601 Read flash Remove Frp done in one and only Cm2
Read info
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 29 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from IDB!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D420739B4E043B3A7
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID    : 0xB637B87508BB41D42DDAFB81B78691B1
INT RAM    : 0x00000000
EXT RAM    : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
[AP] : Initial info read Ok!
Brand     : OPPO
ProdName  : A1601
ProdModel : A1601
Device    : A1601
AndroidVer: 5.1
MTKxCPU   : MT6755
MTKxPRJ   : A1601EX_11_A.26_161222
SECURITY :
IMEI_SW [1] :
IMEI_SW [2] :
BTMAC Addr  : C09F057641D5
WiFi MAC    : C09F057641D5
EXTRA :
LCD : Not info available :(
LCD Res : M_HEIGHT=1280xM_WIDTH=720
TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX
CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw
CAM [1] : imx258_mipi_raw
CAM [2] : ov8865_mipi_raw
CAM [3] :  s5k3p3sp_mipi_raw
MODEM : oppo6750_15331_lwg
Done!
Elapsed: 00:00:37
Reconnect Power/Cable!
Format Done
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 29 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:25
Read Flash
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 29 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Reading Flash Content now ...
USBDL : Init HSUSB Ok!
xGPT : Normalize settings Ok!
Brand     : OPPO
ProdName  : A1601
ProdModel : A1601
Device    : A1601
AndroidVer: 5.1
MTKxCPU   : MT6755
[Read Ok] : preloader_oppo6750_15131.bin
[Read Ok] : recovery.img
[Read Ok] : md1img.img
[Read Ok] : md1dsp.img
[Read Ok] : md1arm7.img
[Read Ok] : lk.bin
[Read Ok] : lk2.bin
[Read Ok] : boot.img
[Read Ok] : logo.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6755 / V1.1.2 / oppo6750_15131 / EMMC
Android Info saved
HWConfig Info saved
FW Size : 3019 MiB
Scatter saved to : C:\Users\sys\Desktop\MT6755__OPPO__A1601__A1601__5.1__A1601EX_11_A.26_161222\
All done!
Done!
Elapsed: 00:03:58
The Following 4 Users Say Thank You to princesaddam For This Useful Post:
Old 01-24-2017, 10:28   #2 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
great bro
can you upload readed firmware .
reg
Old 01-24-2017, 10:49   #3 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Originally Posted by lahdache View Post
great bro
reg
it is signed firmware as some mobile can dead in sptool so still u want i will upload use it at ur own risk
Old 01-24-2017, 10:56   #4 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
thanks .
i need it ; upload pls.
reg
Old 01-24-2017, 12:05   #5 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
Hey my friend can you dump us this firmware and upload it please
Sent from my iPhone using Tapatalk
Old 01-24-2017, 12:19   #6 (permalink)
Member: 1243303
Sonork: 1591167
Thanks Meter: 514
boot not locked
br.....
Old 01-24-2017, 12:58   #7 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Originally Posted by GsmBaguio View Post
boot not locked
br.....
Press and hold vol keys
Old 01-24-2017, 13:08   #8 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
thanks .
reg
https://docs.google.com/uc?id=0B2U4l...xport=download
The Following User Says Thank You to princesaddam For This Useful Post:
Old 02-08-2017, 13:58   #9 (permalink)
Registered User
Member: 2506300
Thanks Meter: 345
Both Volume Key?...............
Old 02-08-2017, 14:00   #10 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Yes Press both Vol + and - then Connect Usb Cable
Old 02-09-2017, 09:14   #11 (permalink)
Member: 1477840
Sonork: 100.1612459
Thanks Meter: 37
read flsah error
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2122
EMICFG_NOT_ACCEPTED_CONFIG
Boot Error!
Operation Failed
Elapsed: 00:00:22
same error
Old 02-09-2017, 09:34   #12 (permalink)
Member: 1477840
Sonork: 100.1612459
Thanks Meter: 37
please solve...
Wait for phone...
Phone found! [ 55 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2122
Boot Error!
Operation Failed
Elapsed: 00:00:11
Old 02-10-2017, 03:32   #13 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 245
your phone its last update firmware..?
Old 05-06-2017, 12:35   #14 (permalink)
hlk
Member: 1294901
Thanks Meter: 12
just download its firmware....use WiseLinkTool_v6.0.1.59 and select only userdata ... then flash and u r done
Page generated in 0.23005 seconds with 8 queries
