10-26-2017, 14:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A33F PATTERN LOCK & FRP REMOVE Done Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 20DF6D6E ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7B8DE71FBE24515C0B6090FD3A0191B9 ID_BLOCK_L : BAC977D6DB4AF471946334EDE70E1823 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A33f ProdModel : A33f Device : A33f AndroidVer: 5.1.1 SWVersion : A33fEX_11.A.29_INT_029_201705311650 Manufact. : OPPO SysPatch : LMY47V QLMxCPU : MSM8916 Done! Elapsed: 00:00:08 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 20DF6D6E ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7B8DE71FBE24515C0B6090FD3A0191B9 ID_BLOCK_L : BAC977D6DB4AF471946334EDE70E1823 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 4 Users Say Thank You to gracy_elec For This Useful Post: |
10-26-2017, 18:05 | #2 (permalink) | |
Junior Member Join Date: Jun 2015
Member: 2408050 Status: Offline Thanks Meter: 9 | Quote:
Sent from my Primo_EF3 using Tapatalk | |
The Following User Says Thank You to cleshera For This Useful Post: |
10-26-2017, 21:05 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
10-27-2017, 04:55 | #4 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
Br | |
10-27-2017, 05:28 | #5 (permalink) |
Member: 2408050 Status: Offline Thanks Meter: 9 | there are files on the internet and all of them are for qualcomm msm flashtool and cannot be loaded with cm2 qlm. and needs a different driver which conflicts with cm2 qlm driver. that's why I needed a cm2 backup of a33f. cm2 backups can be loaded and flashed easily than msm flashtools. Sent from my Primo_EF3 using Tapatalk |
10-27-2017, 08:45 | #6 (permalink) | |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Quote:
i will upload on ios | |
