07-17-2017, 16:15 | #1 (permalink) |
Insane Poster Join Date: Jun 2011 Location: Algeria
Member: 1600534 Status: Offline Thanks Meter: 25 | oppo A37 flashing error ? Code: Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1CA0DBBC ID_BLOCK_I : 007050E1 ID_BLOCK_L : C93B51AD0896838E792E262FE8B3C30B ID_BLOCK_L : 7B0AB417188B33B055A0F52220CFD9E2 Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
07-21-2017, 12:01 | #6 (permalink) |
Member: 1600534 Status: Offline Thanks Meter: 25 | any help for that the phone stuck on EDL MODE Code: Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1CA0DBBC ID_BLOCK_I : 007050E1 ID_BLOCK_L : C93B51AD0896838E792E262FE8B3C30B ID_BLOCK_L : 7B0AB417188B33B055A0F52220CFD9E2 Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! Error : Device stuck in S-EDL! S-EDL : Reset power. Use BootJIG ( probably it is time to seek TP ) Reconnect Power/Cable! and in the device manager see care suite emergency connectivity only no HUSB 9008 port |
