Oppo a37f frp lock done OPPO A37F FRP LOCK DONE IN SINGLE CLICK- Card found : S/N : 94FBD840 , v0134 Infinity-Box Qualcomm Module [QLM] v 1.03 Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1D8E3408 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E5AA193BB ID_BLOCK_L : C060A78CF2F2A277 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
WHEN I TRY TO READ FIRMWARE IT SAY- Card found : S/N : 94FBD840 , v0134 Infinity-Box Qualcomm Module [QLM] v 1.03 Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1D8E3408 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E5AA193BB ID_BLOCK_L : C060A78CF2F2A277 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Read Flash [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1D8E3408 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E5AA193BB ID_BLOCK_L : C060A78CF2F2A277 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__A37f__A37f ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
Frp done but file not read, it is just for report, but i really very satisfied ur qualcomm tab. |
