Old 06-11-2017, 13:39   #1 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
Oppo A39 (CPH1605) dead after flash
this phone is working normally the only problem is cannot be used with simcard because its a demo unit. i tried remove demo features using _********** Demo Reset.apk but not work, so i decided to flash.
now the phone is dead. only vibrate
Read Info and Flashing Firmware
Card found : S/N : xxxxxxxxx , v0136
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from IDB!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A4552ADE4293AB
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0x35626C1B2CB1AFA35CD1F211312CC975
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
[AP] : Initial info read Ok!
Brand : OPPO
ProdName : CPH1605
ProdModel : CPH1605
Device : CPH1605
AndroidVer: 5.1
MTKxCPU : MT6755
MTKxPRJ : CPH1605EX_11_A.11_170414
SECURITY :
IMEI_SW [1] : 86365403xxxxxxxx
IMEI_SW [2] : 86365403xxxxxxxx
BTMAC Addr : E44790F3294B
WiFi MAC : E44790F3294B
EXTRA :
LCD : Not info available
LCD Res : M_HEIGHT=1280xM_WIDTH=720
TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX
CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw
CAM [1] : imx258_mipi_raw
CAM [2] : ov5695_mipi_raw
CAM [3] : ov5648_mipi_raw
MODEM : oppo6750_bc011
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_16021 , Storage : EMMC
Files found : 15 , Set to Flash : 14
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : OPPO
Device Model : CPH1605
Device CPU : MT6755
Device IntName : CPH1605
Device Version : 5.1
Device Compile : 18/11/2016 05:34:53
Device Project : CPH1605EX_11_A.05_161118
Device ExtInfo : CPH1605
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DRAM configured from ScatFW!
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : oppo6750_16021 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000003F80000
Erase : 0x0000000004088000-0x0000000004000000
Erase : 0x0000000009800000-0x0000000001000000
Erase : 0x000000000AB00000-0x0000000002400000
Erase : 0x000000000D400000-0x00000007397FBE00
Flash Erase Done, time used : 00:00:03
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Failed!
Region Finalize ACK not received! Empty battery or Cable problem?
Operation Failed
Elapsed: 00:00:39
Flashing the backup demo firmware
Device Brand : OPPO
Device CPU : MT6755
Device Compile : 4/14/2017 11:46:39 AM
Device Project : CPH1605EX_11_A.11_170414
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Flash Erase Done, time used : 00:00:02
Flash PLC
Image Flash Ok
Image Flash Failed!
Operation Failed
Elapsed: 00:00:38
Old 06-12-2017, 14:12   #2 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
i hope infinity team support this problem
Old 07-06-2017, 12:00   #3 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
up for this. i have the same problem.
Old 07-06-2017, 12:11   #4 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 942
i will give you full solution just wait few minute
The Following User Says Thank You to kothamamun For This Useful Post:
Old 07-06-2017, 12:20   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 942
download this file and flash without box or dongle
https://docs.google.com/uc?id=0BzPXt...xport=download
The Following 2 Users Say Thank You to kothamamun For This Useful Post:
Old 09-08-2017, 13:34   #6 (permalink)
Member: 1612300
Thanks Meter: 9
flash with msm download tool, http://helloponsel.********.co.id/20...9-vibrate.html
Old 09-09-2017, 17:05   #7 (permalink)
Member: 148515
Thanks Meter: 15,715
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Old 09-10-2017, 09:20   #8 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,958
Why do u flash with lower version?
Try to get latest firmware and reflash.
Good luck
Old 09-10-2017, 09:45   #9 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 299
All of User Angry on Infinity Team, You Don't want to understand your Dongle user's mind and Exception, you should shame!!
Page generated in 0.27839 seconds with 7 queries
