08-15-2017, 14:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Oppo A57 [CPH1701] Pattern Lock Reset Done By CM2 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : DABAEE67 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : C7178622140C6B04470317B5125D1A77 ID_BLOCK_L : 6E59C0C97C2ABB33FAF3D8C7FB4AC0BB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to sachu2002 For This Useful Post: |
08-15-2017, 16:27 | #2 (permalink) |
Junior Member Join Date: Jul 2017 Location: India From Kolkata
Member: 2740721 Status: Offline Thanks Meter: 2 | Oppo A57 Pattern unlock Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.12 Operation : Reset Settings [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : 1FBF6E61 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : DD0D8C380E16657E5D0911B31C57106D ID_BLOCK_L : 655CC5C27921A638F10EDFC2E6B13BB0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following User Says Thank You to shabsankar For This Useful Post: |
09-15-2017, 09:02 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: The Land Of Promise
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | how to solve this? Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 4256FAE0 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 5E8C0DBB8F95E4FDDE888E329DD493EE ID_BLOCK_L : F2F55C55D0B61F8F9E97747B5F2EAC1F Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
10-02-2017, 06:34 | #4 (permalink) |
Freak Poster Join Date: Oct 2006 Location: india
Member: 380023 Status: Offline Sonork: 1666713 Thanks Meter: 53 | Operation : Format FS Checking for existing devices...Found Port : COM37 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 2729EC539F0C70FA21C67CD1B8C249998B3D85E480BE31DB27 277ABB926ECC2D Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8937_009.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8937, eMMC, 32 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO CPH1701 [msm8937] Software : CPH1701EX_11_A.17_170712, eng.root.20170821.105511 [Mon Aug 21 10:57:51 CST 2017] Android Ver. : 6.0.1 Preparing Data...Done Formatting Userdata...Done Finalizing...Done Operation Finished. |
10-02-2017, 06:35 | #5 (permalink) |
Member: 380023 Status: Offline Sonork: 1666713 Thanks Meter: 53 | oppo a57 lock with umt Operation : Format FS Checking for existing devices...Found Port : COM37 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 2729EC539F0C70FA21C67CD1B8C249998B3D85E480BE31DB27 277ABB926ECC2D Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8937_009.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8937, eMMC, 32 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO CPH1701 [msm8937] Software : CPH1701EX_11_A.17_170712, eng.root.20170821.105511 [Mon Aug 21 10:57:51 CST 2017] Android Ver. : 6.0.1 Preparing Data...Done Formatting Userdata...Done Finalizing...Done Operation Finished. |
02-15-2018, 12:26 | #6 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2677791 Status: Offline Thanks Meter: 1 | Card found : B7DA1679 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : 27C95EE9 ID_BLOCK_L : 459504A0968EED86C581994B94DF98F5 ID_BLOCK_L : 7F46CFD8633BA802EB04C9F4E8BB31AA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! UNINSTALL QUALCOM DRIVER |
09-30-2020, 12:25 | #7 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1177050 Status: Offline Thanks Meter: 7 | Card found : D5198C85 , v0145 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : 9AAC456B ID_BLOCK_L : C31B9A2618086F004B071BC916411E7B ID_BLOCK_L : 98AB323F8EDCB525C4E12AD1F544D645 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
09-30-2020, 13:56 | #8 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Quote:
Wait for new update, update may be release 2020 to 2021 | |
