10-25-2017, 09:11 | #1 (permalink) |
Freak Poster Join Date: Feb 2017 Location: INDIA
Member: 2682035 Status: Offline Thanks Meter: 22 | oppo a57 read info done by cm2 qlm module 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : EF00C824 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 1AD041FFD3D1A8B982CCD276D198D7B2 ID_BLOCK_L : 241F86833A60E179304D9E8DA1F07AF1 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Brand : Android ProdName : CPH1701 ProdModel : CPH1701 Device : CPH1701 AndroidVer: 6.0.1 SWVersion : CPH1701EX_11.A.21_INT_021_201708202024 Manufact. : OPPO SysPatch : MMB29M DevComTime: 8/20/2017 1:23:39 PM QLMxCPU : MSM8937 USERData : ENCRYPTED GCSec : EMPTY Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
10-25-2017, 09:20 | #2 (permalink) |
Member: 2682035 Status: Offline Thanks Meter: 22 | oppo a57 remove frp nd pattren lock done with cm2 dongle qlm Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : EF00C824 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 1AD041FFD3D1A8B982CCD276D198D7B2 ID_BLOCK_L : 241F86833A60E179304D9E8DA1F07AF1 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
10-25-2017, 09:32 | #3 (permalink) |
Member: 2682035 Status: Offline Thanks Meter: 22 | Oppo a57 read nd write falsh done with cm2 dongle Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Android Device Manufact.: OPPO Device Model : CPH1701 Device CPU : MSM8937 Device IntName : CPH1701 Device Version : 6.0.1 SWVersion : CPH1701EX_11.A.14_INT_014_201705071629 CU_SWVer : OPPO Device Compile : 5/7/2017 8:58:56 AM Device ExtInfo : CPH1701 Load Ok! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : EF00C824 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 1AD041FFD3D1A8B982CCD276D198D7B2 ID_BLOCK_L : 241F86833A60E179304D9E8DA1F07AF1 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Flash Chain : 62 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : lsplash.img Flashing : sec.dat Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : cache.img Flashing : system.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : ap.mbn Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:03:44 Reconnect Power/Cable! |
