11-15-2017, 10:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A71 CPH1717EX AndroidVer: 7.1.1 MTK 6750/55 FRP REMOVE Done Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_170815 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : OPPO Device Model : CPH1717 Device CPU : MT6755 Device IntName : CPH1717 Device Version : 7.1.1 Device Compile : 8/14/2017 3:17:42 PM Device Project : CPH1717EX_11_A.02_170815 Device ExtInfo : CPH1717 Ready to Flash! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6E [eMMC] : FLASH_CID : 150100474536424D42030857F2A57409 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2B142F03980DD716A92665EA3648BA58 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : CPH1717 ProdModel : CPH1717 Device : CPH1717 AndroidVer: 7.1.1 MTKxCPU : MT6755 MTKxPRJ : CPH1717EX_11_A.02_170815 Done! Elapsed: 00:00:17 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6E [eMMC] : FLASH_CID : 150100474536424D42030857F2A57409 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2B142F03980DD716A92665EA3648BA58 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 9 Users Say Thank You to gracy_elec For This Useful Post: |
11-15-2017, 10:46 | #2 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Quote:
let me know how did you boot please when i try each time secure boot error | |
11-23-2017, 14:53 | #5 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 110 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
11-23-2017, 15:16 | #6 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A71 CPH1717EX SECURE BOOT DA FILES HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK : https://drive.google.com/open?id=1wM...0TEU9A33pBYZTJ 1)SELECT MT6755_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
11-25-2017, 13:38 | #7 (permalink) | |
Member: 2636476 Status: Offline Thanks Meter: 61 | Quote:
11-25-2017, 14:11 | #10 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Link Working Rechecked |
The Following User Says Thank You to gracy_elec For This Useful Post: |
11-26-2017, 07:17 | #12 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Dubai
Member: 1259046 Status: Offline Sonork: 100.1608453 Thanks Meter: 1,229 | OPPO A71 Boot Solution / Read Info/Read File / Format/FRP Reset 100% Done http://forum.gsmhosting.com/vbb/f296.../#post12804354 Br IM3022 |
11-26-2017, 17:31 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
11-27-2017, 01:48 | #14 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
