10-28-2018, 04:26
#1 (permalink)
Member: 1974137
Sonork: none Thanks Meter: 22 | Oppo a83 erro cm2 help UNIT: OPPO A83 2018
PROBLEM: PASS AND FRP
Here the error in CM2 please help me
LOGS Quote:
Card found : E1641B40 , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : DA USB VCOM Port (COM8)
MODE : PRELOADER PORT
PORT : 8
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : Oppo : F5 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
PORT : 8
BROM : Init BROM
BROM init passed!
MODE : Oppo : F7 | Manual : Disabled
AGENT : DA_BR_HIGH.bin
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
PTFN : PreLoader USB VCOM Port (COM8)
PORT : 8
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
Reconnect Power/Cable! | |
