03-05-2019, 15:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: NIGERIA, DELTA STATE, WARRI
Member: 53891 Status: Offline Thanks Meter: 41 | Oppo a83 new security error....pls help Card found : 2873D962 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM Port (COM72) MODE : PRELOADER PORT PORT : 72 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM69) MODE : BOOTROM PORT : 69 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM69) MODE : BOOTROM PORT : 69 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : A3 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
03-05-2019, 16:30 | #2 (permalink) |
Member: 53891 Status: Offline Thanks Meter: 41 | Tried again and this happened with several format options of choose: Card found : 2873D962 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A534A9652635DD EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002002A ERR : SEC_IMG_TYPE_MISMATCH ERR : 0x00001000|0x00001000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A534A9652635DD EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! Patch Level : N6F26Q Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2018-11-05 Build Time : 1542990224 Product Manfct : OPPO Board Platform : mt6763 Product Model : OPPO A83js Product Brand : OPPO Product Name : A83js Product Device : M6763D Product Board : full_oppo6763_17101 Product Info : oppo6763_17101 SW Version : A.22 SW OTA Version : M6763D_11.A.22_0220_201811232239 SW OTA Name : A83jsEX_11_A.22_181123 Display ID : A83jsEX_11_A.22_181123 Kernel Info : 4.4.22-G201811232239 USERDATA : ENCRYPTED Done! Elapsed: 00:00:59 Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A534A9652635DD EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002002A ERR : SEC_IMG_TYPE_MISMATCH ERR : 0x00001000|0x00001000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A534A9652635DD EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002002A ERR : SEC_IMG_TYPE_MISMATCH ERR : 0x00001000|0x00001000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 7ADB205F0E6CE7D2D4447DB9C5C7649360457E0E7E7A09A53E 0D91442AC0D3F4 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A534A9652635DD EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 47FEF4147D769064DFB5F3F4DB4BCB29 DA : USB : HIGH-SPEED Boot done! |
03-09-2019, 07:52 | #7 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
Re open exe leave everything default Force format + FRP must work on this... Note : After make port (Brom) you have to disconnect Test Point Backup Factory File Before Format | |
