Old 02-06-2019, 10:27   #1 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
Oppo CPH1725 password problem
OPPO F5 Youth
Operation : Identify [ v2.04 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM12)
MODE : BOOTROM
PORT : 12
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+ARB
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000  F3: 0000 0000  V0: 0000 0000 [0001]
BROM : SOCID : 6DC800D1A1001887F2B0560C46752AB8C4F8ABA532367D9337F46ED4D2CCC19C
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00007017 : DA SEND ERROR!
  ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
  INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
The Following User Says Thank You to haji rahim For This Useful Post:
Old 02-06-2019, 10:34   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
select oppo F5 from list and repeat
Note: if you using TP (test point) method
do not connect TP long
after make port disconnect TP
Page generated in 0.11598 seconds with 8 queries
