08-16-2017, 09:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | OPPO F1f PIN UNLOCK DONE WITH CM2QLM:- Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 084BCE3E ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 4BBDD72F8E14010CFB50A0AD6A314189 ID_BLOCK_L : 067DC36A6FF658EDE0CF80794BBAB497 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : F1f ProdModel : F1f Device : F1f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 Done! Elapsed: 00:00:30 RESET LOCKS Code: Operation : Reset UserLocks [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 084BCE3E ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 4BBDD72F8E14010CFB50A0AD6A314189 ID_BLOCK_L : 067DC36A6FF658EDE0CF80794BBAB497 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:37 Reconnect Power/Cable! WBR sahil2000ind |
