03-15-2017, 07:44 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | oppo F1s All Dongle Failed Report >>Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. >> >>Connecting... >>CPU TYPE:MT6755/50 >>Hardware version:CB00 >>Software version:0001 >>SecCfgVal :0x01000000 >>BromVersion :0x05 >>BLVersion :0xFE >>Boot downloading complete! >>Cannot connect with the phone, the program has terminated. |
03-15-2017, 07:45 | #2 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | CM2 Failed Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
03-15-2017, 08:00 | #4 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | miracle Box Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Waiting for USB Port... >>none usbport, maybe driver not installed |
03-15-2017, 08:04 | #5 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Thanks! for your prediction About MTK while team is busy LG and Samsung many time people posting for this unsupported CPU why cant team add this immediately This is international Phone , not belong to single country or Sample Required type |
03-15-2017, 08:19 | #7 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
all Vote for method 2 so team is working do u think programing is easy???? when somethng is Ready team will Release it without delay until then enjoy the other modules updates dont spam with cant hack bla wla | |
03-15-2017, 10:40 | #9 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
1st thing never compare/post other product here. 2nd thing preparing update is not like cooking maggie in 2 minutes. It takes lots of time and effort to prepare and make a bug free, tested and stable update. Anyway if you know programming and can "add this immediately" (as per your wordings) you are always welcome to contact team. One more thing when team starts to give updates in one module users start to ask for other, so it's not possible to update all modules all together at a time, so when something will be ready team will release it. Br. Infinity Box Team. | |
03-15-2017, 10:52 | #10 (permalink) |
Freak Poster Join Date: Mar 2008 Location: India
Member: 718338 Status: Offline Sonork: 100.1623688 Thanks Meter: 43 | one more oppo f1s Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 41 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 0000 BB_CPU_HW : 0000 BB_CPU_SW : 0000 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
03-16-2017, 08:07 | #12 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | [IMG]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxISEhUSExMVFRUVFRUVFRUVFxUVFxUVFRUWFhUXFR cYHSggGBolHRUVITEhJSkrLi4uFx8zODMtNygtLisBCgoKDg0O FxAQGi0dHR0tKy0tLS0tLS0tLS0tKy0tLS0tLS0tLS0tLS0tNy 0tLS0tLS0tLS0tLS0tLS0tLS0tLf/AABEIAKgBLAMBIgACEQEDEQH/xAAbAAACAwEBAQAAAAAAAAAAAAACAwEEBQAGB//EAD8QAAICAQMCBAIHBgUCBwEAAAECAAMRBBIhBRMiMUFRBmEUM nGBkaGxFSMzUtHwQmLB4fEWckNzdIKys7Qk/8QAGAEBAQEBAQAAAAAAAAAAAAAAAAECAwT/xAAmEQEBAQEAAQQBAgcAAAAAAAAAARECEgMhIjFBBBMjQlFhgZ HB/9oADAMBAAIRAxEAPwD54iyxWsr0OGGRLVcByLGhYCKY4AyCVEa IIEICWBtcfiIQSwpjAaiMBgQowGDC3TkEnZKiMwgJIEICaQIhC GIQAhCxChgQhKaXidiNGJ2ZF0rE6NzIMYFZkExhEiTAkmAYjqf U66uD4m9FHn9/sJ53UdWtc+e0egXj8T5manNqXp6VliykxKOsWDg4b5nz/KX9N1NWOGBU/iP9pmyxZVlkinEsssUySKrmLaOZIplgIYRLywyxLiAholxHsIl xAruIgiWGIPrFEQKNZIwQcGaWk1g8m4P5TNWMUTKvR1cx6iedo uZfIzT0/UP5h94/pCtHE4CDXaDyDmNEsZqVjUMUI1VmkPBhqIgGORpcNOQxoiqyI0 CTDUhZ2yQpjVWaxnQAQgsbthAShYSGEjAsLbAWEnbY3bBKyABJ xJxE33qilmIAHmTGGjbHmfxnnOr9fH1KefQv6f8At9/tlHrPV2tO1chB6erfNv6TMrHrOnPGe9Zve+0GNOx8R5zznz8/f5w+1xOaw+QMktx9sl1ZiNh9IYIiApP2e0Nz+czY1K09JrCvhb kfmPsmiHBGQczzy2Y4MeuqK8jM5tNZ4lhAp1qt8j7Q2lQphEvH MZna3Xhcgct+Q+2MNdqtSqefmfIDzmZZrGPHAz7e3tEPkksx5k emZckTXZx5Qjqm+UEwCJGhKI1ZwUH5QwpHznPWhrDUSExG7faT TDanxyODLtOoz58SgBGqSJZ1hZrTQmPVzM6l/Y/7y5W+Z057lc+ubPpZUxoiVMarTpjGnKDDa0KMsQAPU8CZOr62q 8J42+X1R9/r90yLL3tObCT7D0H3S5/UaWv68T4aePdyP/iD+pk6bUMeSxJHrkmUFqEsUoVk6sxZMeg0nUPR+fn/AFmtUQRkHM8rU8uUXsvIJnPybx6QLDCzEPXgo8S5Pyj9J11G81 K/n+k2y1Qslklb9o14J3Zx7A8/ZxzPNdX+I7DlEBrHz4c/0+78YnOpbjZ6t1Wqjg+J/wCUen/cfT9Z43qHULLTljx6KPIfYP8AWV3tHnkfjEPeo9Z255kc7bTVW WFTAzMy7qHoo+8/0lay528yce3p+Ez1WuY1DaoJyw/GKOpBPLcTNkZmdaxr1a1QPrD8DFNqkLZz+szCZGZFax1SfzCH9 NT+YTELSCZmxW19Or/m/I/0jq+tqOCSR9hnnSYOZPFdbes6xu4BIHy8z98ofSV+f4SnIzLqL T6oegMWdV8hEEwSZFOOpb5QDe3v+Qi8wSZBtrGLxFLGoZwbOC5 k7JCiPXmNaCs9B8KuVOoICHGlvcb0rsAdEyhG9TggzCKzX6BrK qTabRYRZTZUO3syO4NpJ3H0l0xd1q1V6HTBG8dqvZZmlMuy3On NxYsoXZgAcNyTjOBXpoH0VrC+0DUVI47YZlDV3FXRtw3DCPlOA Tt59q+p1yvVp68EGlLFJ9CXustBHr5OB90bRqk+jW0sGy9lViM Mbc1rahD+uMWny9RBi98WaOpNRbVUzhVsYYxtCYONoO4l1+ZxD 0/Q2sGmQWBkspufinxjttYzoFU5ubKkLyM8DiVet62u+03KGRrPF YGwyhz57GHO08nkcZlujX1GvTo62/uhaCayo+vYbFZc+oJ8uM48xL5JjG6j0/TqQanY5ByCmxkYMQVdNxAPAPDHzmpougC4aSsWgC5bgh7QBFit yrndl1z5MTwPSH13X16g1/xCyIVNtoHcs8RI37SfqjgZJPz9u03W6tOulNgOdO9p4KkOtmT4 fXcDNTqs3lOl6Np3R7F1OVpKi09ogYfcFNPizblht5CeYPAzh9 Hw8lllaJd4bqnsrdq9vNe8Mlihjs/ht4gW9OOePL1fEaJRdSqMWs7OGOAo7bMTkZz6zV+GPiAW3aKtg 26mvWixfCK7UanU2qAR4gfFtP2Zm8qbFmzp9RRmouNpR60dCmx h3W2Vso3NlS+F5wQWHE5dPQ1x0qanfqQWQL2iKntXINSXFuWJB AJUKTjnkGecr6zTp6mXRi4PY9LtZqO34BRYLa0Ra/rZcKSxx9QAKMmWK+taRL/pldN4vDm1Kmas6eu4kncH/iMisdwTA8gC2JrxTVzWpSulq1LXlRerlE7Rd99blLQV3gbVwPE SM5Ax54L4kSlNa1FeoaqsDxfuSxVu0jqlY3k2s5OBkqAWxmeb1 2tFmn01OGzSt6sxx4u7c1gI+5sc+s3B8SU/SG1G29Hv05puatk3VWbalFulJweRUQVYggOQGmsxkafDrvdpaz fci6zuLWbqWrsWysgFbKu4QFO5CGDHhvLiZ13RqTVdZVqe69AR rV7RVCrWLUWptLkuAzryVXIORNOr4n06NomCalvod9j7rGRmuS 3YzFufC4ZAAuSAvqTMHomsSmrUV2ByLtOKgU25V1tqtUkN/hzXg+uDB7LvxZodNS1Qodju0+ndga9g8dCN3MmxuWJJK48OcZM D9n6b9nLcXcXnU21gCvdu21VstWd4wPFu3bc5YjHGSjrGvruSk hbFurqqpfJU1stKCtHT/EGIC5B444M7TdQrGlbTuLA4uOoosrK8WGtaytgb/D4EORyCDwYFs/DVIu+itqwNVuFeztE0LceBS2o35DbvCWCFQeM+syenaAWahKLH 7O6ztMzLu7bklRuAI43YBOeASecYm43WdG2o+mtTf9I7nfNIas aZr92/fv8A4gQv4ymD5kbsTAWi3U2kKrWW2s7bVGWdjud9qjkn6xwIFr TdCdl1Bc7GodKdm3c1mpsdkSheQAco5J9Avkcy6PhuprjpE1Yb VAlAnZYUNcMg0peXyWyCoY1hScc85l/4y6q6vp0wEvr7Wq1POc6411rlh6MqVISPRrLBKy9Z0aX/AE1KbvpG83LSzVnTpeTu37/4jIGO4JgeQG7EztVh9T6cKqNPcHLC+ux9pTYa2qc1uh8R3cjhu PsEHrvTDptRZQW3msqN2NudyK/lk4+tjz9Jp19S0tmnpq1KXs+nN23ttWFuW1+4VtZvFWd24blDc HyzJ+Jtbp9VZdq13pZY9IWk7cDFZFzHGcoNlQXkHxNkcRoy9J0 zuUXXK43UbGarbyaXYIbVbPO12QEY4Dg59Jfp+GMrWz3rWp0/0q4lGIooawJR5H95ZZkEIMfWXnk4s/BGisa8WGtjpcWU6uzkVpp7K273ccfUITxLnzZVxzEn4iD6jU2W 1FqNWvbetSEeutGQ6ftkggPWKqwAeDgg+eRLVKr+H6bAtlOpZ6 u9XTcWo2W0m3Iqc1C0q6MVIyHGD5iVk6GTqNTp94B0yati23If 6IHJAGfDu2efOM+stXdWppqNOjW3x21W22ajYGbsEtVWqVkhU3 MWJ3EkgeQHOmvXtAt+ovFOqJ1aalLQxp/cDUq2/s4/iHc2AW2+HPBJ4aPFEyIwLxzIgBtglYzMAmQCRIxJMiBsrD3SFQ RiVj3nBvKJHj0eKWn5xqUSUynVt98euD9sWlM3+hL3ar9MFBcp 3qeBu7lPLqp8zur7nGfNRJGox+0Za0Oi7hRRZWpeztgMWBBwCG YKpIUltoPPIPtmemdtK7rgKa+n2NVqio+tXTS1xd/fe9GpXP8AnQTz2l6/dqKdJc+wM3Vu34UQba2XT2FAQPLczfjNzmnlBanpzV1tazphLj Q4ydyuAx5yANpCNggn7pT0Ny2mzY1arUncttsZkqRSwQZZVZiS zAAKpJJiviCwtptbkk46wQMnyAq1XAg/CvVLadH1A1ttwulYEqjctqUQnxA+nE3OJ+Wb0zNd1azahFleHB OEO5kwzJtsJHhbw7sD0ZT6zKNmSecn15yfvn0HoNqm/pe5EYW6LU12qVT95XW2rCq3HmBVWN3n4fPzmQOqWarQazvBMUr p7KVWqusUM2oWsrWFUELtcjBz5D15nSZPpzvuw+i9PbVXpp0et bLDtTuFgCx8lyqsQT5DjHuRKi8z6b03WW1dZp0NSL9GrtrCUiu sg1hA41BfbvLn+Jvzz5eXE+e9I0bXWU1oFLWPWiBvqlnYKu7/AC5Iz8prTFZcHyIhhZ7zqNov0muLWm7smlkb6LXRTSzakVldOw cuFK712sBwo9RMX4SQWWPpSARqqnrUkA7bgC9Dg+Y8aheCOHOY 8jGAqzjj3nuV6Kuoqq0CqEvoOmsufAD7dW3/APTuPtT3dMPlsaKfquPpGsFo01D3rRT2tOll2yusvXWocqqJ23 RmJOWIHsY1MeMxICT3vUtKraq/R9sKdTRRbWDWlbLrF09dxGFyK+4e4jKCRusGPeYfxDikU6QAA0 oHvO0bjqLhvcFvUIprrx6FWjTGb0XpLam3tI9aMVdwbS6qdg3M AURjnaGby8lPOcAwvSm7LXmypUDtWmWbdc6gMwpUKSQAyklto8 Q5zxNT4NYfS0/8vU//AJL4/VdSs/ZmmrDeBrtUpG1OVVdKyjOMjljzn1k1ceV2yNmZ6n4a1Rro1pKJ ZtprsRbERwtv0mmtX5HON5OPI+oMvdPI1yaNtYwYnqD6dnAStn pNVNi1sUA43sQD5gOY0x4YVD5R12jZVR2GFtDNWcjxBXNbEAHI wysOfaet6P1G7Vag6TVKgp23d2oU11jRrXW7b6yqg1GsgDJPPk c5lLrvUrm0HT0ZvC1NoI2oMtVqbFAyFzlV2+vqCck5k0eYKyCI 9bbKnDDwujBhuUcMpBGVYc8gcGet1lSUd/qVaKK7qUOkQgMqanVb1tUA5Umntanj0/d/KFeJZR64/wCJG2es6x1W7RWV6bSqnZanTtWpprs+m92pGZ7NylrSzlkwDxt 2gAiO+JdPXXT1GmsL26NdpSg8J7Pdq1HeQP8AW2h1Ccn/AAD1zIPLaHQm3ubSo7VVlzFiR4awOBgHLEsqge7Dyl2j4csdqV Wykm+izUVHdZhhUXFlf8PiwGqzg+HwnxeWWfEekKaPpu5NrPTq XORglW1LGtj7+Egj5ETZ+H/4nSf/AEnUf/s6hA8FvzzIJnVrwPsH6ScGUCYOIzbJ7ZkCTIxHdkzu1Gq1VSNW v7ZlpqSP8X6n/SWK+pe+D+InnsrpsaCfafwjVbHr+IlSvqg/l/P/AGjR1NP5TM+67FkE+5+4mN0pKWLajutiHwOG8SkjHhOOOCRKB6 qn8h/v7p1fVUz9Q/n/AEj3NjQ01IVbFWx1W0bbQNuLFB3APx4hnmNp07rX2k1FiVl1t2 AKF7i42vjHDDaOfkJnftVM4CH78/lxCXqi54qb8ZfLo+LWtFriwPqbGF5VrdxU9xkxsZxtwSMDH2QV 0BCsoswrhQ44wwRtygj1wwyPnKC9aI8q/X1OYyrr7DzqHywf+ZL10fFpiu0LWqahlFW/thSqis2Ah9vBxu3NkD3MRp+nahFcVXFRYhSwDGHQ/WVsDkH2i/8AqD17Zz/3/wCk9P8ADOtS2u+5+0BUqbVudwuXsVNz9tc4GSAAeSR6TPn2Zyx 6r+oqiouqtCqRgKcbQp3AA4zgEAgeXErDSahnLNYN+4vvKqWLk 5JGBnOecz0dYa1qK61TddQ1teHP7za1m5OQcWjay7eB4POV9Sj BGdWpftlRaK7S7VFsgF/CFYbhtyjMMmZvqepJuLJzaparV9UY7TabVdWVsnaNjfWD++7Az 5k4HtMY6q2lwDSqMu5w4G3BAzlW9fqjkT2vQEc6qim1tPvcpv0 xtfuitwCTgAAMEO/bu3Y/w+k+Y2a2y9gxJywwATwA3GPQeuMzrx+5ftnrxn09GOvIHNmT3b A4tdScuLANwLeuctmO0PxAKM9pnTdjcEOMlRhTj3HofMTK1Hw+ 1S2OLtPb2WVbhU7satzbAW3IoZd2FyhYZIl//pG4WLW12lV7NhpBtb9+tig1mrCcBi20F9mSCPSd5zjna0dL1fT lqr7vpFracp2VypA2eJEdmbcq5AORngHgSh/1EAbD2lLW7+7ncN/cYM+7nBBZVPl6TKRCEcFTuDICMZI+sMY984Euaz4ctXuDuUtbU hezTq5NqKgy+fDsLKMllVyRg8cReZTV/o/xNVXaXVPo9hBXdWTyGIJGV5Ayo9PaaHgsXbhSu52xy4DvjeePJ jtXJ8+BPOD4btdkXdUUeprxeHPZWtDtcs+Mgq2FK4zuIGORO6f 0jUBUf6RRR3SO13rHR7QGKhlCI21C2RufaDicu/Sv8tb56n5j0KUKqsqhAHAVgVOGAYOA2fMblBwfUCTXWe21KlQh YO1e3ClgMBiuME4AGflMxtVfVULLXrx3bqcBtzJdQVV0fjGcOC NpIIOczQI1DY8VKKaE1JtYnalTkBCSATuJZRhQTkieezvcdZeM WdZrdRYhqstZ0IGVOSGx5BifrAcYzmJ0eptqCqBlFsS3tHPbLo QysVHzUfbiIpTUm7t92plFYta3I7K1HjcWKhgckLtI3ZIGJV12 rtqVH30212bgllZbaWTG9SGClWG5TgqOGE1J2l65PZN77rFY7m y7cFyM+LBPr9ss9VdWrqorVu1VvI7gUM1lhy7FQSF4CgAE+RPq Zhjr1npsP2/7GB+27s8hPsAJz+JlzpPLls6TqGpqTt12uiAkhVOApb623+XPO SMZlbQ6i3TlmpY1lhhtuBuHn4h5Hn3mc3WH8iB92R/rFnq7f3/tHyNi/rtRbcoW2x7FDM4Dkth2+swz6mDVqbqxUEsZRSWakAkdtnzvKe2 cnPvk+8yruqN7j7+IP7Rcj0mvkz5Q6ygFizKCSSSfck5JPvBOm T+Qf398qvrm+X6wDrj8vwl+SbFlqU/lH6RfbX2H5mV31p/sRZ1be4/CXKasNWv8oizWPYSsdQ3v+UH6UfeXKmkAScQBZ/ZhBh7y4g1X7JMDdLNpG1T7gfpM32UtTCDfZFlxIF49QRGIeM/2YQBiltHoMxqnPkCJMEquPT/SNqU54H4AE/KQJH0gAcEkfgJMtXD0dvbn58czX0PUkq0mpR2w9q1KgAJ3FNQj sMgYGFB88TzNmsY8A4HsIkZmp6W/a+WPe9L+I9OjaCxrdvZq1NdqlLNyF21LVsMLhge6g8JJHOQJgd L16/RtbU1nba2moU5DkM1V6WlBsB2khSATgZxkjzmKiRyrOs4kZ2vc 6bXaNupV9TfUhUNtdz09u43JZhQycJsNYOTuDZKjAXM8p04U1X Vi092lLEFhTcO5UrDeVDAMMqDjIB59JTLTlE2j22o6pV9H1lLa uhhai/Rq6NM9VaLXeloRsUqVdgu0A5Ax4m5zKGq6nW2t01wYmuoaAMcN x2K6RaACMnBR/Lzxx5zzixiQjb12o7dptQ9wfSu8jbLFSwK+8YZyPXggpkc8++v 1TrZY3XVa+tUsFjLUdMBqAbA2aWYU7cYYqbO5yOfPieU1VlZVA hs4Hi3spXPH1ABwPPziIHpauq6ddL+zzYe1YpusvxZhNX4WrUV 4yaVFao2FyWbePqiVNRZRqkoZtSmneqiui1LUubIpBVbKmqRg2 VxlDtIIPJBzMFoowN+pNNZpTpvpKUmvV23I1td2LKbKqq8halc q47IOw/zefEu63qVIvpfS6/sCvRVacG2m1lZqjtZNQoRl2uDu4WxcjBxgGeUzBYSYr3Ok+K9N Vc9atXWt2nqWy+ml2pXVV2FyUpsXd2WGFOFyDyFxKHVOoJea6n 19TqGZmNdLpVUSoAPFSNYzAYOF4wPu8c6RRExeJ+GvJprd7hh9/ENG+f2eZmWLz/zHLqVPmPw/pM3msr7E49IruH2P4f7yBap8iP0gNYw+yQ90tYfb8h/Wcm5s8AY5/vmLTUg+Z/GO0z8N9h/QzPd8ZrfPyuE5PykHPynbx+UhvtmsZ0JBgYM5j8/0gbvYwDx9kHHzEgsZBJlUraPnJFfr+sH7oahvslR2MS3qea0+Y H6RAEs6iwBF9eB+k5d/fLfM9qrV1mNCLEC4+kg2feZ08aycLQIR1fsMfrKjOTOAmpxE00 2/8yMSAsYomsRyrGok4CFmUEJxaBmSsqDUQ8wMwlECxpkDMq+5A+ 4melX4aKhHBLZww8vQjzyoBGSM4yBnnGRPMU2bWDeeCD+E29P8 T2oDgDy28k8AjBx93H/Akr2fpuvRnN/c+/8AP/Gh1fpVlh7lvGAB4e0owMeijn668/5hA1HwmU4yTw54IHFfDHxKOOfylDU/E1rk7gDng8+mVPt/lX8BCb4pu/HORxjxfW4x68598n3j3enz/Sf2/wBVX610jsDnduyOCVPB9eBxMV5qdR6s1wO4ckgk5544mWYeL9R fTvf8P6wGYWYLCDmV5xMIsiMkEQquyxZEskRbLIEiNrvI9f6QG WARJYq0bFPmPvEt6fGG/wC0/L0MyQZZo1ACsvJyCPyxOXqcbzkb4sl2mPgeX9YPcH5xG4+8LeP b8JrKxg2I9cfhOIiu0DzmDsMeyYYwgnP95nFjAJ+cYogRiC1sR ukS+K6Zukmw/wBPl9kCSBLiJhATgIQEo5RGBZyiGJUSoh5i904QGZk5i8yRAMQ hBEnMA1hgxYhAyoYDNfoXRG1RYBggXHJBOSfTzmMDNvovVq6ab lIs7jj92yMVAOOM8+/MisvVU7HdM52sy58s7SRnH3RRlptRUSWKMcnJyx8z5n7c5gm6o/8Ahke/iJ9sY9/X8R7c0ViYJMl8ZOM4ycZ88emYJMAWgEwzAMggNCzAMgGAyARJz IMACIthGmCYCSIBEcwgESKDdJDSCIJgGDDDxOZ26TAxxnyitrS cyd0YFQgJAhCUSIQkCEIBAQ1EEScyoLMnMAGTmAQkmCTOEA1hQ Z2YB5hAwFhCAYk5gZnZlDVMIGKE9Pf8MKlTWGw5VC2NoxkDOPO TR5wmdAzJBlHSDOMgmB0FpMgyAcwSJJg5gSDJzAMjMAzBInAzo AmDiEYJgAYJhmCYAEQTDMEyKGRmSRIMCRDE6dCCEKdOlHZnZnT oE5k5kToBCEJM6BOZwkzoEiFmdOgdJzOnQHaUjem44Xcu77M8z 1/Vev0PTYivlmUgDDD8yJ06MHjd07M6dKOMjMmdAAwZ06QdBM6dA gwTOnQIzJBnToHZgmdOgCYJkzoAGQZ06AJgzp0iv//Z[/IMG] |
