04-23-2018, 20:36
#1 (permalink)
Member: 229016
Sonork: 100.1590620 Thanks Meter: 130 | Oppo f1s mt6577 flash WITH MT2CM2 Hi to all
i try to flash with cm2mt2 but not success Quote:
card found : 3ed03844 , v0136
infinity-box chinese miracle mediatek service module [ mtk ] v2.00 r1
operation : Identify [ v2.00 r1 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert usb cable in phone
waiting for device connection ...
Ptfn : Mediatek usb port (com322)
mode : Bootrom
port : 322
waiting boot ack ...
Brom : Skip ack verify
brom : Init brom
brom init passed!
Chip : Mt6755 , sbid : 0x8a00 , hwvr : 0xcb00 , swvr : 0x0001
type : Modern raphael
brom : Seclevel : 0x00000000
brom : Secmode : Plain [+prl]
brom : Bootrom
agent : Look for suitable bootchain in da ...
Agent : Mtk_allinone_da.bin
agent : Found mt6755
agent : Mtk_download_agent
brom : Sending 1st da ...
Brom : Da sent
brom :transfer control to da ...
Da : Agent started!
Da : Sync
da : Mode : Brom
da : Ext_ram not initialized!
Emi : Dev : Infinity
emi : Src : Infinity-box_internal_emidb_v0
emi : Cnt : 0009
emi : Init emi from internal db
emi : Ext_ram cfg passed!
Da : Boot to 2nd da ...
Da : Boot 2nd da failed!
Err : 0xc0070004
err : Da_hash_mismatch
error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Reconnect power/cable!
Operation : Identify [ v2.00 r1 ]
mode : Bootrom
port : 322
brom : Init brom
brom init passed!
brom : Bootrom
Brom : Da sent
Da : Agent started!
Da : Sync
da : Mode : Brom
emi : Cnt : 0009
Err : 0xc0070004
Operation : Write flash [ v2.00 r1 ]
error : Firmware not selected! Nothing to do!
Created by infinity-box (c) chinese miracle ii (c) 2016
device brand : Oppo
device model : A1601
device cpu : Mt6755
device intname : A1601
device version : 5.1
device compile : 2/10/2017 1:04:43 pm
device project : A1601ex_11_a.28_170210
device extinfo : A1601
operation : Write flash [ v2.00 r1 ]
repartition : Enabled
flash verify : Disabled
pre-erase : Enabled
verify hw/sw : Enabled
xdata backup : Disabled
files :16
[fl] : Set : Preloader_oppo6750_15131.bin
[fl] : Set : Recovery.img
[fl] : Set : Md1img.img
[fl] : Set : Md1dsp.img
[fl] : Set : Md1arm7.img
[fl] : Set : Lk.bin
[fl] : Set : Lk2.bin
[fl] : Set : Boot.img
[fl] : Set : Logo.bin
[fl] : Set : Tz1.img
[fl] : Set : Tz2.img
[fl] : Set : Secro.img
[fl] : Set : System.img
[fl] : Set : Cache.img
[fl] : Set : Userdata.img
[fl] : Total size : 0xc6c3c0e7 [ 3.11 gb ]
mode : Bootrom
port : 322
brom : Init brom
brom init passed!
brom : Bootrom
Brom : Da sent
Da : Agent started!
Da : Sync
da : Mode : Brom
Emi : Dev : Mt6755
emi : Src : Preloader_oppo6750_15131.bin
emi : Cnt : 0009
emi : [00] : Emcp : Emmc+lp/ddr3 , id : 150100524531424d42 : Ven : Samsung | dev : Re1bmb : Ram : [ 3.00 gb ]
emi : [01] : Emcp : Emmc+lp/ddr3 , id : 90014a484247346132 : Ven : Hynix | dev : Hbg4a2 : Ram : [ 3.00 gb ]
emi : [02] : Emcp : Emmc+lp/ddr3 , id : 150100525831424d42 : Ven : Samsung | dev : Rx1bmb : Ram : [ 3.00 gb ]
emi : [03] : Emcp : Emmc+lp/ddr3 , id : 13014e51334a393756 : Ven : Unknown | dev : Q3j97v : Ram : [ 3.00 gb ]
emi : [04] : Emcp : Emmc+lp/ddr3 , id : 150100525831344d42 : Ven : Samsung | dev : Rx14mb : Ram : [ 4.00 gb ]
emi : [05] : Emcp : Emmc+lp/ddr3 , id : 13014e51334a393757 : Ven : Unknown | dev : Q3j97w : Ram : [ 4.00 gb ]
emi : [06] : Emcp : Emmc+lp/ddr3 , id : 150100524331344d42 : Ven : Samsung | dev : Rc14mb : Ram : [ 4.00 gb ]
emi : [07] : Emcp : Emmc+lp/ddr3 , id : 150100524836344d42 : Ven : Samsung | dev : Rh64mb : Ram : [ 4.00 gb ]
emi : [08] : Dram : External dram [lp/ddr3] , undefined : Ven : Unknown | dev : : Ram : [ 4.00 gb ]
emi : Init emi from preloader
Err : 0xc0070004
Reconnect power/cable! | i can flash or not ?
