10-10-2017, 09:52 | #1 (permalink) |
Insane Poster Join Date: Mar 2010 Location: indonesia
Member: 1270521 Status: Offline Thanks Meter: 21 | oppo f1s unlock network Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A421B3602C739B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xBB0DAF3C506A945FBBE5F6B7268A1994 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : A1601 ProdModel : A1601 Device : A1601 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : A1601EX_11_A.12_160820 SECURITY : IMEI_SW [1] : 862651039739930 IMEI_SW [2] : 862651039739930 BTMAC Addr : CC2D830A586B WiFi MAC : CC2D830A586B EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1280xM_WIDTH=720 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : imx258_mipi_raw CAM [2] : ov8865_mipi_raw CAM [3] : s5k3p3sp_mipi_raw MODEM : oppo6750_15331_lwg Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A421B3602C739B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xBB0DAF3C506A945FBBE5F6B7268A1994 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok SIM Lock Status : Locked! Unlocking now ... Error while unlocking, somethig went wrong! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! can anyone explain. about this error |
