08-16-2017, 17:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 915829 Status: Offline Thanks Meter: 29 | oppo f3 cph1609 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 1 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! whats problem this mobile pattern lock many box supported but infinity not supported why?? |
08-16-2017, 20:14 | #2 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | Quote:
08-17-2017, 09:12 | #3 (permalink) |
Member: 915829 Status: Offline Thanks Meter: 29 | Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 00000000 OPK_DATA : 6B62B769692C0CBE97447336C29B772808C304CE406B5BFA85 40E962333CAFDD Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8976_007.ufl]...Done Executing Loader...OK Hardware : 8976, eMMC, 64 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO CPH1611 [msm8952] Software : CPH1611EX_11_A.12_170522, eng.root.20170522.220125 [Mon May 22 22:05:30 CST 2017] Android Ver. : 6.0.1 Preparing Data...Done Formatting Userdata...Done Operation Finished. Module Ver. 1.0 Report Post |
