Old 06-30-2018, 07:00   #1 (permalink)
Member: 599037
Thanks Meter: 103
Exclamation oppo f3 failed to boot
hello all, while all other boxes are doing those fones successfully, we still are searching for those fu******ing working boot loaders and wasting our time,
this time i have a f3 with below error
Card found : 81E95962 , v0136
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM8)
MODE : BOOTROM
PORT : 8
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : BOOTROM
MODE : 0_base : BASE_v1724 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00007017 : DA SEND ERROR!
ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO type!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
MODE : BOOTROM
PORT : 8
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
AGENT : DA_SWSEC_CRYPTO20.bin
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
MODE : BOOTROM
PORT : 8
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
AGENT : DA_PL_CRYPTO20.bin
have tried all settings, does anyone know any working setting????
i have even tried in the cm2mtk and cm2mt2 but nothing seems to work...
plz hlp
Old 06-30-2018, 07:17   #2 (permalink)
Member: 599037
Thanks Meter: 103
UPDATE:
I found the da and auth file but still cant format or reset the fone, the fone remains in same condition
Operation : Reset Settings/Format FS [ v2.00 r4 ]
MODE : BOOTROM
PORT : 8
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
MODE : Oppo : F3 | Manual : Disabled
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6755
EMI : SRC : preloader_oppo6750_16391.bin
EMI : CNT : 0006
EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ]
EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393756 : VEN : UNKNOWN | DEV : Q3J97V : RAM : [ 3.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100524836344D42050F7CDAE33415
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : C01EF96610866EDE1469D678D400A1B6
DA : USB : FULL-SPEED
Boot done!
ERR : 0xC0010001
ERR : ERROR
ERR : 0x00000000|0x00000000
Error : Failed erase block!
Try select another format mode!
MODE : BOOTROM
PORT : 8
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0006
EMMC:
Boot done!
ERR : 0xC0010001
ERR : ERROR
Old 06-30-2018, 07:23   #3 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
change protocol to 1 and try again format/force format
Old 06-30-2018, 07:24   #4 (permalink)
Member: 2596094
Thanks Meter: 83
plz hlp
select base 1712 and force format
Old 06-30-2018, 09:50   #5 (permalink)
Member: 599037
Thanks Meter: 103
base 1712 shows same error as post 1...
Old 06-30-2018, 09:54   #6 (permalink)
Member: 599037
Thanks Meter: 103
tried al format protocols, but same error, formatting failed..
Old 06-30-2018, 12:33   #7 (permalink)
Member: 599037
Thanks Meter: 103
i hope atleast team can provide the knowledge to the customers that how can they use the memory tool to tackle this problem and format the specific zone of user data,
btw my problem is solved after all by flashing the fone...
Old 07-01-2018, 16:27   #8 (permalink)
Member: 2438408
Thanks Meter: 380
use latest tool and press voloum + key
The Following 2 Users Say Thank You to alexid For This Useful Post:
Page generated in 0.19775 seconds with 8 queries
