02-10-2018, 16:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: somewhere
Member: 227038 Status: Offline Thanks Meter: 78 | Oppo F3 Plus cph1613 Successfully read FW an full wip pattern locked 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 9DA432A5 ID_BLOCK_L : D51A9B46A472557EB7CF5A102A426A80 ID_BLOCK_L : 035DAB0D461127FC6E8EB1F0AC0EBDBD Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : CPH1611 ProdModel : CPH1611 Device : CPH1611 AndroidVer: 6.0.1 SWVersion : CPH1611EX_11.A.09_INT_009_201703172221 Manufact. : OPPO QLMxCPU : MSM8952 DevInfo : MSM8952__OPPO__OPPO__ANDR_v6.0.1__CPH1611__CPH1611 __CPH1611__CPH1611EX_11.A.09_INT_009_201703172221 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : system.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : ap.mbn [Read Ok] : driver.iso [Read Ok] : reserve4.bin [Read Ok] : reserve_exp1.bin [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main2.bin [Read Ok] : cdt.mbn [Read Ok] : gpt_backup2.bin Android Info saved! Read finished! Configuration : MSM8976 / eMMC Firmware Size : 4535 MiB Done! Elapsed: 00:10:29 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 9DA432A5 ID_BLOCK_L : D51A9B46A472557EB7CF5A102A426A80 ID_BLOCK_L : 035DAB0D461127FC6E8EB1F0AC0EBDBD Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! Card found : , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Last edited by gsm-nisse; 02-10-2018 at 16:08. Reason: pattern locked Oppo F3 Plus cph1613 Successfully read FW an full wip |
03-14-2018, 17:16 | #2 (permalink) |
Member: 227038 Status: Offline Thanks Meter: 78 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 4975916B ID_BLOCK_L : 8F50C11CEE281344FD85142E6C1820CA ID_BLOCK_L : 506CFA5E774216CF1DDF86C19D5DEE8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : CPH1611 ProdModel : CPH1611 Device : CPH1611 AndroidVer: 6.0.1 SWVersion : CPH1611EX_11.A.13_INT_013_201707150952 Manufact. : OPPO SysPatch : MMB29M DevComTime: 15/07/2017 02:35:42 QLMxCPU : MSM8952 USERData : ENCRYPTED GCSec : EMPTY Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 4975916B ID_BLOCK_L : 8F50C11CEE281344FD85142E6C1820CA ID_BLOCK_L : 506CFA5E774216CF1DDF86C19D5DEE8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : CPH1611 ProdModel : CPH1611 Device : CPH1611 AndroidVer: 6.0.1 SWVersion : CPH1611EX_11.A.13_INT_013_201707150952 Manufact. : OPPO QLMxCPU : MSM8952 DevInfo : MSM8952__OPPO__OPPO__ANDR_v6.0.1__CPH1611__CPH1611 __CPH1611__CPH1611EX_11.A.13_INT_013_201707150952 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : system.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : ap.mbn [Read Ok] : driver.iso [Read Ok] : reserve4.bin [Read Ok] : reserve_exp1.bin [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main2.bin [Read Ok] : cdt.mbn [Read Ok] : gpt_backup2.bin Android Info saved! Read finished! Configuration : MSM8976 / eMMC Firmware Size : 4535 MiB Done! Elapsed: 00:08:28 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 4975916B ID_BLOCK_L : 8F50C11CEE281344FD85142E6C1820CA ID_BLOCK_L : 506CFA5E774216CF1DDF86C19D5DEE8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 |
The Following 2 Users Say Thank You to gsm-nisse For This Useful Post: |
