Old 09-18-2018, 20:27   #1 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
greentel x1 frp remove.
i got green tel x1 phone with frp
1. i was try CM2MTK (was try press VOL+, +,- without key press)
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : LOCKED with CERT
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : 00007017
Boot Error!
Operation Failed
Elapsed: 00:00:05
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DA Select done, will use SecMode DA
Boot Error!
Operation Failed
Elapsed: 00:00:04
2 then i found Greentel X1 Pro MT6580 DA & Auth file then try CM2MT2
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM10)
MODE : BOOTROM
PORT : 10
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
Info : Device is not supported yet!
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
3 then try with AST read info ok but frp fail
Infinity-Box Android Service Tool [AST] v1.03
Operation : Identify [ v1.03 ]
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
INFO : max-download-size: 0x8000000
INFO : partition-size:userdata: 32000000
INFO : partition-type:userdata: ext4
INFO : partition-size:cache: 10000000
INFO : partition-type:cache: ext4
INFO : partition-size:system: 99000000
INFO : partition-type:system: ext4
INFO : partition-size:metadata: 2760000
INFO : partition-type:metadata: raw data
INFO : partition-size:nvdata: 2000000
INFO : partition-type:nvdata: ext4
INFO : partition-size:frp: 100000
INFO : partition-type:frp: raw data
INFO : partition-size:expdb: a00000
INFO : partition-type:expdb: raw data
INFO : partition-size:logo: 800000
INFO : partition-type:logo: raw data
INFO : partition-sizeara: 80000
INFO : partition-typeara: raw data
INFO : partition-size:keystore: 800000
INFO : partition-type:keystore: raw data
INFO : partition-size:secro: 600000
INFO : partition-type:secro: raw data
INFO : partition-sizeemkeystore: 200000
INFO : partition-typeemkeystore: raw data
INFO : partition-size:recovery: 1000000
INFO : partition-type:recovery: raw data
INFO : partition-size:boot: 1000000
INFO : partition-type:boot: raw data
INFO : partition-size:lk: 60000
INFO : partition-type:lk: raw data
INFO : partition-size:seccfg: 40000
INFO : partition-type:seccfg: raw data
INFO : partition-sizerotect2: a00000
INFO : partition-typerotect2: ext4
INFO : partition-sizerotect1: a00000
INFO : partition-typerotect1: ext4
INFO : partition-size:nvram: 500000
INFO : partition-type:nvram: raw data
INFO : partition-sizeroinfo: 300000
INFO : partition-typeroinfo: raw data
INFO : partition-sizereloader: 40000
INFO : partition-typereloader: raw data
INFO : off-mode-charge: 1
INFO : warranty: yes
INFO : unlocked: no
INFO : secure: yes
INFO : kernel: lk
INFO : product: T961W_V1_D_YX_A8PRO_X1_1S
INFO : version-preloader: 0.1.00
INFO : version: 0.5
INFO : Done!!
OEM : FAILunknown command
Done!
Elapsed: 00:00:05
Operation : Reset FRP [ v1.03 ]
Mode : Remove MTK GENERIC FRP
Connect Ok!
FRP Erase FAIL!
Done!
Elapsed: 00:00:07
is there any help to do this phone frp remove???
Old 09-18-2018, 23:32   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Contact me on telegram (IST 10:00) we will check
https://t.me/kamal_singla
Old 10-31-2018, 14:26   #3 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
infinity support team igot same phone model again could u pls share even DA file for this mode i got this Greentel X1 Pro MT6580 DA & Auth files but its not work,
so pls sahre DA for this model.
Page generated in 0.18402 seconds with 8 queries
