09-11-2019, 19:21 | #1 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Tanzania
Member: 2697846 Status: Offline Thanks Meter: 77 | Oppo F7 not supported by Exe CM2MT2 V2.06 Any assist from the team will be appreciated. Here are the logs Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Update Ok! Load IDBase v46104 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 338A3C6F3626B7AF8E12F3EF07D81BB3AF4A8163326CBD983D C06D459507B6CD BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 22023F5C4CDC99998B8E7F1B2E68BB4 DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
09-12-2019, 17:46 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, I can't give any exact advice right now. Probably there is a possibility that it may be slightly different HW config for the units with the same name or it may he some kind of unit HW fault. |
09-13-2019, 05:47 | #3 (permalink) | |
Member: 2697846 Status: Offline Thanks Meter: 77 | Quote:
Maybe a different HW config. A set boots up well but can’t be used because of screen lock passwords. Sent from my iPhone using Tapatalk Pro | |
09-15-2019, 06:35 | #4 (permalink) | |
SOFTWARE VERSION of the set. I’m I missing something or I should wait maybe will be supported in future updates Sent from my iPhone using Tapatalk Pro | |
