06-09-2019, 15:41 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | oppo f9 (copy) no service problem how to solved Operation : SP Unlock [ v1.58 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393010DF15EC9D7077 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393010DF15EC9D7077 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x656888AB1266E86B991BBDE30D62536B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Slot[1] SIMLock Info : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Slot[2] SIMLock Info : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Done! Elapsed: 00:00:14 Reconnect Power/Cable! read info logs Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393010DF15EC9D7077 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393010DF15EC9D7077 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x656888AB1266E86B991BBDE30D62536B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : F9 Pro ProdModel : F9 Pro Device : F9 Pro AndroidVer: 5.1 CU_SWVer : V1.0.9 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P55 SECURITY : IMEI_SW [1] : 358468741673716 IMEI_SW [2] : 358468741673724 BTMAC Addr : 143456795ADA WiFi MAC : 0014BC14C203 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V23_P8_1_wg_n EXTRA : LCD : Not info available LCD Res : M_HEIGHT=960xM_WIDTH=480 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=ft6xx6_ges TOUCH [1] : gsl915 CAM [0] : STOM_HAL_IMGSENSOR=gc2385smipi_raw CAM [1] : ov9760_mipi_raw CAM [2] : ov9762_mipi_raw CAM [3] : ov9760m_mipi_raw CAM [4] : ov9762m_mipi_raw CAM [5] : ov5648_mipi_raw MODEM : STOM_MODEM=hct6580_we_a_l_hspa_b1b2b5_coclk_RTM728 9_v131F LOCALE : K_PRODUCT_LOCALES=en_US ar_EG fa_IR pt_BR pt_PT fr_FR ru_RU tr_TR el_GR vi_VN my_ZG es_ES es_US tl_PH th_TH de_DE in_ID ms_MY zh_CN it_IT Done! Elapsed: 00:00:21 Reconnect Power/Cable! Last edited by vsy; 06-09-2019 at 15:47. |
