11-11-2017, 08:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Dubai
Member: 1259046 Status: Offline Sonork: 100.1608453 Thanks Meter: 1,229 | World's 1st A71 CPH1717 MT6755 Read Info / FRP Reset Done By Infinity Box World's 1st A71 CPH1717 MT6755 Read Info / FRP Reset Done By Infinity Box Read Info Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6E [eMMC] : FLASH_CID : 150100474536424D42030857F2A57409 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2B142F03980DD716A92665EA3648BA58 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : CPH1717 ProdModel : CPH1717 Device : CPH1717 AndroidVer: 7.1.1 MTKxCPU : MT6755 MTKxPRJ : CPH1717EX_11_A.02_170815 Done! Elapsed: 00:00:17 Reconnect Power/Cable! FRP Rest Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6E [eMMC] : FLASH_CID : 150100474536424D42030857F2A57409 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2B142F03980DD716A92665EA3648BA58 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! Br IM3022 |
The Following 6 Users Say Thank You to im3022 For This Useful Post: |
11-11-2017, 08:23 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | Quote:
The Following User Says Thank You to mcclinic For This Useful Post: |
11-26-2017, 07:15 | #4 (permalink) |
Member: 1259046 Status: Offline Sonork: 100.1608453 Thanks Meter: 1,229 | OPPO A71 Boot Solution / Read Info/Read File / Format/FRP Reset 100% Done ****************************/file/q3667...y%20IM3022.rar Br IM3022 |
The Following User Says Thank You to im3022 For This Useful Post: |
11-26-2017, 17:34 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
03-15-2018, 08:24 | #8 (permalink) |
Junior Member Join Date: Mar 2018 Location: albay
Member: 2817333 Status: Offline Sonork: NONE Thanks Meter: 0 | hello my friend i have a problem ...i need a good firmware of this phone oppo a71 can you help me about that ..pls feedback help me it almost 3weeks befor i recieve the problem is frp so ill try to reset cm2 basically not succesfully so i deside to fullflash after flashing good but doesnt open it....OPPO A71-CPH1717 MT6755 Last edited by bakura; 03-15-2018 at 08:31. |
