03-10-2016, 04:12 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Quang Tri- Viet Nam
Member: 723166 Status: Offline Sonork: 100.1590944 Thanks Meter: 129 | oppo neo 7 a33w read file not done??? Operation : Read Flash [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100463331324D42068116C82EA2A1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! infinity team hepl me! thank! |
03-10-2016, 06:13 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hi, Answer in logs my bro dont hold any vol keys and dont use any special cable so called boot cable use normal cable Sent from my S_plus using Tapatalk |
The Following User Says Thank You to princesaddam For This Useful Post: |
03-10-2016, 12:11 | #11 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: bali
Member: 1778254 Status: Offline Sonork: sornork id Thanks Meter: 36 | Quote:
if work maybe eMMC problem | |
The Following User Says Thank You to putu1996 For This Useful Post: |
03-10-2016, 15:40 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It will change nothing. If phone without press any key detect, but not boot - open DeviceManager and try check its VID and PID info. That need for add it to normal boot mode. |
