11-30-2016, 06:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | oppo R831k preloader erased User selected Preloader file : preloader_OPPO72_14079.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [2] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A146406149 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A146406149 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6B82A76F302EE56765340DE9A5BEEE4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [2] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 1799 PartTable Init Ok , Count : 18 All Done Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A146406149 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A146406149 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6B82A76F302EE56765340DE9A5BEEE4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : OPPO72_14079 ProdModel : R831K Device : OPPO72_14079 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : R831K_11_A.10_140911 SECURITY : IMEI_SW [1] : 864816024162335 IMEI_SW [2] : 864816024162327 BTMAC Addr : A43D789703DD WiFi MAC : A43D789703DD EXTRA : LCD [0] : FWVGA_HX8379_13079 LCD Res : 854x480 TOUCH [0] : gt9xy_14079 CAM [0] : ov5645_yuv CAM [1] : hi253_yuv MODEM : OPPO72_hspa_14079 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hdpi Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-30-2016, 23:42 | #2 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, This Is Not Erased PreLoader, It's Just Because Of Pressed Boot Key (Volume Up). Make Sure About eMMC IC Is Okay - "Make Test" On Extra -> Repair, Tab In MTK Module. If Everything Is Okay Then First Try With Format, & If Won't Solve So Flash With Good FW. |
