Old 12-29-2015, 17:03   #1 (permalink)
Member: 257603
Sonork: 100.1605284
Thanks Meter: 147
OPPO R831K sucessfull virus removed
Operation : Remove Viruses [SmartAV] [ v1.40 ]
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164040500A27784B1F1
DA Stat : v4.2 on BBID : 0x88
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040500A27784B1F1
[eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 34
Removing infected files and scripts ...
SmartAV Report : Removed 34 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
Done!
Done!
Elapsed: 00:01:05
Reconnect Power/Cable!
thanks team
Old 12-30-2015, 04:18   #2 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
did u used boot keys or not....???
Old 12-30-2015, 04:18   #3 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
Old 12-30-2015, 05:45   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
If FlashId inside CM2 EMIDB - doesn't matter, pressed bootkey, or not. DB updated in every CM2 version.
Page generated in 0.14031 seconds with 9 queries
