11-21-2017, 07:04 | #1 (permalink) |
Major Poster Join Date: Jun 2007 Location: 21st Century
Member: 533695 Status: Offline Thanks Meter: 5 | Oppo r9m dead I tried writing R9m_11_A.38_161117 but still dead after successful write Only vibrates and shows Recovery at lower left of screen and thats it |
11-21-2017, 08:54 | #3 (permalink) |
Member: 533695 Status: Offline Thanks Meter: 5 | I see no previous logs in logs folder 20:03:39 Available Ports:COM14 20:03:39 Current Port:Com0 20:04:39 Current Task: Write Factory Files 20:04:42 BasicInfo : 20:04:42 Brand : OPPO 20:04:42 ProdName : R9m 20:04:42 ProdModel : OPPO R9m 20:04:42 Device : R9 20:04:42 AndroidVer: 5.1 20:04:42 MTK CPU : MT6755 20:04:42 MTK PRJ : R9m_11_A.26_160716 20:04:42 Display ID: R9m_11_A.26_160716 20:04:42 Board ID : full_oppo6755_15111 20:04:42 Build Date: Sat Jul 16 19:54:01 CST 2016 20:04:42 20:04:42 20:04:42 HIGH BOOT 20:04:45 20:04:45 Operation: 1. Power off the phone. 2. Please insert USB cable within 40 seconds. 20:04:45 20:05:16 MediaTek USB Port (COM24) 20:05:16 20:05:16 Connecting... 20:05:16 CPU TYPE:MT6755/50 20:05:16 Hardware version:CB00 20:05:16 Software version:0001 20:05:16 SecCfgVal :0x01000000 20:05:16 BromVersion :0x05 20:05:16 BLVersion :0xFE 20:05:16 Boot downloading... 20:05:25 EMMC_ID:0x150100524331344d42 20:05:25 EMMC_PRODUCT_NAME: 20:05:25 EMMC_BOOT1_SIZE:0x400000 20:05:25 EMMC_BOOT2_SIZE:0x400000 20:05:25 EMMC_PRMB_SIZE:0x400000 20:05:25 EMMC_GP1_SIZE:0x0 20:05:25 EMMC_GP2_SIZE:0x0 20:05:25 EMMC_GP3_SIZE:0x0 20:05:25 EMMC_GP4_SIZE:0x0 20:05:25 EMMC_USER_SIZE:0xe8f800000(58.24G) 20:05:25 INT RAM: 0KB SDRAM EXT RAM: 0KB DRAM 20:05:27 Finding partition. 20:05:27 backup path:C:\Users\EGM\Downloads\VOLCANO\InfernoTool_MT K_EXT_Volcano_V1.4.1_20171103\MTK_Vol_EXT\backup\p reloader_oppo6755_15111_20171107_200527.bin 20:05:27 preloader Writing 20:05:27 preloader_backup Writing 20:05:27 recovery Writing 20:05:29 md1img Writing 20:05:32 md1dsp Writing 20:05:32 md1arm7 Writing 20:05:32 md3img Writing 20:05:33 lk Writing 20:05:33 lk2 Writing 20:05:33 boot Writing 20:05:35 logo Writing 20:05:35 tee1 Writing 20:05:35 tee2 Writing 20:05:35 secro Writing 20:05:36 system Writing 20:09:49 cache Writing 20:09:50 userdata Writing 20:10:48 Flash writing complete. 20:10:48 Write factory file successfully! |
11-21-2017, 08:57 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | We don't need any other device logs, if you have used Infinity-Box software and have any problem post logs here, else we can't help. P.S Next time don't post other device logs in this section. Br. Infinity Box Team. |
11-22-2017, 13:01 | #5 (permalink) |
Member: 533695 Status: Offline Thanks Meter: 5 | Oppo r9m log Sorry about that sir i made a mistake Here is log: ========================= Start ========================= 10/14/2017 / 4:49:28 PM ================================================== ======= Card found : S/N : A422C66F , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [10/14/2017 / 4:49:56 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D4207AD759E0C837D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xDC74F27DF4EB2EE3EBC078198B2972D5 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : R9m ProdModel : OPPO R9m Device : R9 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : R9m_11_A.40_170302 EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1920xM_WIDTH=1080 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : imx258_mipi_raw CAM [2] : s5k3p3sx_mipi_raw CAM [3] : s5k3p3sp_mipi_raw MODEM : oppo6755_ac0033_lwctg_c2k Done! Elapsed: 00:00:47 Reconnect Power/Cable! Finish at : [10/14/2017 / 4:50:43 PM] Start at : [10/14/2017 / 4:50:52 PM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D4207AD759E0C837D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xDC74F27DF4EB2EE3EBC078198B2972D5 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:55 Reconnect Power/Cable! Finish at : [10/14/2017 / 4:51:48 PM] |
