12-16-2017, 16:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Oppo R9s Plus Pattrn remove Error Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 9F1C922F ID_BLOCK_L : 439405D02AE42F083959D06A50DCFC0E ID_BLOCK_L : 8BC52385DE99AF74F636297824860525 Use CM2 Internal Loader Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
12-18-2017, 12:11 | #5 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Card found : 0000000 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset UserLocks [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 9F1C922F ID_BLOCK_L : 439405D02AE42F083959D06A50DCFC0E ID_BLOCK_L : 8BC52385DE99AF74F636297824860525 Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
03-07-2018, 03:42 | #6 (permalink) | |
Crazy Poster Join Date: Feb 2014 Location: Singapore Age: 53
Member: 2131519 Status: Offline Thanks Meter: 8 | Quote:
