Old 12-13-2016, 01:30   #1 (permalink)
Member: 1898834
Sonork: abdelhakim.ch
Thanks Meter: 14
oppo r9tm not flahing
hi
please can you help me
i have made a backup of an oppo r9tm 64gb, i earased fone, but no i can't write back this backup or flash any other firmware, i tried different roms:
-MyStockRom.com-X9009EX_11_A.23_160923.tar
-[firmware27]X9009EX_11_A.17_160529
-R9tm_11_A.14_160325
its original backup: MT6755__OPPO__X9009__X9009__5.1__X9009EX_11_A.22_1 60910.
log:
Scatter Load Ok , BaseBand : MT6755 , Project : oppo6755_15111 , Storage : EMMC
Files found : 15 , Set to Flash : 14
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : OPPO
Device Model : X9009
Device CPU : MT6755
Device IntName : X9009
Device Version : 5.1
Device Compile : 10/09/2016 10:32:57
Device Project : X9009EX_11_A.22_160910
Device ExtInfo : X9009
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 76 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D420759DBD4FC5373
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0x01E24278EF5F7664B596B6E17940BB58
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : oppo6755_15111 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000003F80000
Erase : 0x0000000004088000-0x0000000004000000
Erase : 0x0000000009800000-0x0000000001000000
Erase : 0x000000000AB00000-0x0000000002400000
Erase : 0x000000000D400000-0x0000000E813FBE00
Flash Erase Done, time used : 00:00:04
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Failed!
Something wrong with files or connection!
Operation Failed
Elapsed: 00:00:20
Reconnect Power/Cable!
Page generated in 0.17731 seconds with 7 queries
