08-19-2011, 20:27 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | orange miami problem. Code: COM87 [VCP0] selected module v4.00 Device: Orange-Miami Checking data, wait... Action: write flash NAND write: Firmware ZTE-G-N281_ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ENG_EN_P107A3V1_0_8B07_2010-10-22_En_Fr_Es_Orange-Miami.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... done firmware patch (general #1)... not required firmware patch (general #2)... not required firmware patch (general #3)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1044.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 0FA4:S_FT_DA_INIT_SYNC_ERROR error: last error: 0FA4:S_FT_DA_INIT_SYNC_ERROR Disconnect... done Finished, time used: 23 sec Remove/Install battery now ! info dat: COM87 [VCP0] selected module v4.00 Device: Orange-Miami Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1044.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 0FA4:S_FT_DA_INIT_SYNC_ERROR error: last error: 0FA4:S_FT_DA_INIT_SYNC_ERROR Disconnect... done Finished, time used: 20 sec Remove/Install battery now ! |
08-20-2011, 02:18 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | Hello, Please, download and use MModule v4.01 (version 4.00 has problems with boot process in some cases). |
08-20-2011, 20:36 | #3 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | now this is the prblem: Code: COM87 [VCP0] selected module v4.01 Device: Orange-Miami Checking data, wait... Action: write flash NAND write: Firmware ZTE-G-N281_ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ENG_EN_P107A3V1_0_8B07_2010-10-22_En_Fr_Es_Orange-Miami.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... done firmware patch (general #1)... not required firmware patch (general #2)... not required firmware patch (general #3)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: ORANGE_OSP_SP_P107A3V1.0.7B03 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_OSP_SP_P107A3V1_0_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_OSP_SP_P107A3V1_0_7B03.BIN project-id: ORANGE_OSP_SP_P107A3V1.0.7B03, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/01C00000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.01, database date: 19.08.2011): ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_OSP_SP_P107A3V1_0_7B03.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash (3): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 2 min 33 sec Remove/Install battery now ! |
08-20-2011, 23:14 | #4 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | I am new, so it takes a while to get use to this. I found one flash that did work, but now imei is wrong. Where is the repair imei option that I read so much? mode 2 and mode 1? I do not find any option to repair imei, only repair bad software, calibration, bad license but not the imei thingy |
08-20-2011, 23:45 | #5 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | It is ok now!! Using forum search, and thanks to faisal's videos I finally got how to enable the imei thing |
The Following User Says Thank You to hugmax For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
