12-29-2011, 19:44 | #1 (permalink) |
Junior Member Join Date: Nov 2003 Location: Poland Age: 44
Member: 43664 Status: Offline Thanks Meter: 8 | Orange Sydney ZTEG-N295 died after flash So i readed codes: Code: COM33 [VCP0] selected module v4.13 Action: read unlock codes unlock method: read codes Model: ZTE-N295 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase #2/1 failed Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 19 sec Remove/Install battery now ! Action: read/check information Model: ZTE-N295 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: gbaB Software version: EFS-EE-ORG-P107A20V1 Software date: 2000.00.00 Barcode: 260471704496 P P 10P P P10P imei-1: 357714041013801 Finished, time used: 5 sec Remove/Install battery now ! ==== [2011-12-27 14:38:33] ==== COM33 [VCP0] selected module v4.13 Action: read unlock codes unlock method: read codes Model: ZTE-N295 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: EFS-EE-ORG-P107A20V1.0.5B02 Version: 10AZTENJ35_GEMINI_10A 115 byte(s) read imei: 35771404101380 connection Ok 216 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 204 byte(s) read reading data... 188 byte(s) read lock[1] code: + 682028033284 lock[2] code: + default lock[3] code: + 11112222 lock[4] code: - 33334444 lock[5] code: - 55556666 lock[6] code: + 77778888 lock[7] code: + 99990000 if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 24 sec Remove/Install battery now ! Code: ==== c:\InfinityBox\MModule\MModule.exe [2011-12-27 14:45:00] ==== http://www.infinity-box.com http://www.infinity-best.com http://www.infinity-cdma.com http://www.pinfinder-box.com http://www.language-editor.com http://www.content-extractor.com sales department: [email protected] support forum: http://forum.gsmhosting.com/vbb/f296/ Loading data, wait... [Infinity Box] MModule v4.13 smart-card: connected S/N: 0C06:0118 Wait... trying to select model: /N295 model selected via command line: ZTE-N295 Device: ZTE-N295 Initialization done In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [2011-12-27 14:45:34] ==== COM33 [VCP0] selected module v4.13 Device: ZTE-N295 Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: EFS-EE-ORG-P107A20V1.0.5B02 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: 10B502F0 bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E project-id: EFS-EE-ORG-P107A20V1.0.5B02, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.13, database date: 22.12.2011): ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 64Mb number of areas/bytes to read: 1:04000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\MModule\ZTE-N295_ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E__firmware_20111227-151107.B4M.bin Disconnect... done Finished, time used: 25 min 47 sec Remove/Install battery now ! Code: ==== [2011-12-27 15:11:37] ==== COM33 [VCP0] selected module v4.13 Action: "sp-unlock" unlock method: smart fast Model: ZTE-N295 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: EFS-EE-ORG-P107A20V1.0.5B02 Version: 10AZTENJ35_GEMINI_10A 115 byte(s) read imei: 35771404101380 connection Ok 216 byte(s) read reading data... reading data #2... reading data #3... building new data... writing data... 204 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 23 sec Remove/Install battery now ! Code: COM33 [VCP0] selected module v4.13 Device: ZTE-N295 Checking data, wait... Action: write flash NAND write: Firmware ZTE-N295_ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E__firmware_20111227-151107.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: 10B502F0 bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: EFS-EE-ORG-P107A20V1.0.5B02 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: 10B502F0 bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E project-id: EFS-EE-ORG-P107A20V1.0.5B02, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.13, database date: 22.12.2011): ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... incorrect ext bootloader signature: 10B502F0 bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 7 min 42 sec Remove/Install battery now ! I can only flash it, tried all flashes from support. Code: COM33 [VCP0] selected module v4.13 Device: ZTE-N295 Checking data, wait... Action: write flash NAND write: Firmware ZTE-N295_ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E__firmware_20111227-151107.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: 10B502F0 bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: EFS-EE-ORG-P107A20V1.0.5B02 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E project-id: EFS-EE-ORG-P107A20V1.0.5B02, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.13, database date: 22.12.2011): ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B02.BIN_FLNHYC0UEE0AF2P_3S60E This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... incorrect ext bootloader signature: 10B502F0 bootloader version: ZTENJ35_GEMINI_10A_BOOTLOADER_V005_MT6235B_EFS-EE-ORG-P107A20V1_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done Finished, time used: 7 min 27 sec Remove/Install battery now ! When i try to format ffs for example: Code: COM33 [VCP0] selected module v4.13 Action: reset settings ("format ffs") Model: ZTE-N295 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 22 sec |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
REWARD-Please can somebody help me unblock a orange nokia phone and unlock 6150 | andrew bennett | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-07-1999 17:25 |
