Old 03-16-2008, 11:21   #1 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
Orange Tokyo
Want to see Orange Tokyo in List of Supported phones
Will be Nice gift by Infinty Team.
I have sent u Readed Full flashe and eeprom by Infinity MModule
here [email protected]
Reg
Irfangk786
Old 03-16-2008, 16:05   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Thanks ! Mail received, small request sent to your mail back.
Hope this mode will be supported on days.
Old 03-16-2008, 17:53   #3 (permalink)
Member: 130995
Hello,
Software for tests just sent to your mail.
Waiting for results.
Old 03-16-2008, 19:34   #4 (permalink)
Member: 137489
Thanks Meter: 68
We hope that Infinity support it as soon as possible ....
Old 03-16-2008, 22:11   #5 (permalink)
Member: 130995
@Gerti
if you have prone for test on hands I can send you software for test too, just let me know.
Old 03-18-2008, 09:03   #6 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
Have tested Ur new software but
No success I have sent u logs back to ur email
Still "Enter USP Code"
Old 03-18-2008, 09:15   #7 (permalink)
Member: 130995
Hello,
As I can see from your log, you have selected model "Orange-TR1", but it was need to select "Orange Tokyo".
Please, select "Orange Tokyo" model and try again.
Old 03-18-2008, 11:18   #8 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
Unlock Method :Read Code log
But still "Enter USP Code"
COM26 [Serial2] selected
Action: read codes
unlock method: read codes
Model: Orange-Tokyo
Checking data, wait...
19200 autodetect
Initializing[6219:8B02:8B01]...
CPU: MT6219
chip: 0031:C9C1:E34E
CPU: MT6226MA detected
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226M,E02
Date: 2005.04.12
Version: 1.0
Version: DS606_332B43_SW_MyWay_V4.67
Version: DS606_6226_MBPCB_V1.0
44 byte(s) read
imei: 35931201007652
connection Ok
148 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
Finished, time used: 13 sec
Remove/Install battery now !
Unlock Method :Standard log
Device: Orange-Tokyo
eeprom backup enabled, it may takes several minutes !
Action: unlock
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
boot step size: 0400
Boot Done
Initialize...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program
Files\InfinityBox\MModule\backup_security\id.69F44 387.
[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN_C8168624].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 69F44387
identification#1 protocol ver: 05
ver. sw1: DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN
ver. sw2: DS606_332B43_SW_MyWay_V4.67, DB79E937
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom
[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN]_20080318-120559.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Files\InfinityBox\MModule\backup_system_log_69F443 87_DNET26_06A_PCB01_GPRS_MT6226_S01.DS606
_332B43_SW_MYWAY_V4_67.BIN_C8168624_20080318-120715.B0X.bin
Finished, time used: 129 sec
Old 03-18-2008, 11:36   #9 (permalink)
Member: 130995
Hello,
Please, check, is imei from back label is the same as was readed by softare.
Also, please, make one more test: make "format ffs" and let's see is phone still locked or not (restore imei after format).
Thanks !
Old 03-18-2008, 13:20   #10 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
Yes IMEI is ok as lable
Yes I did FFS After FFS now It's asking for "Network code"But befor FFS it was asking for "USP Code"
after FFS i tried to unlock but still "Enter Network code"
But in log Network status is OF"Network subset lock: Off"
COM35 [Serial2] selected
Action: read codes
Model: Orange-Tokyo
19200 autodetect
CPU: MT6219
Connecting, wait...
Date: 2005.04.12
Version: 1.0
44 byte(s) read
connection Ok
148 byte(s) read
Phone lock: Off
Network lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
Finished, time used: 27 sec
Old 03-18-2008, 17:19   #11 (permalink)
Member: 130995
Hello,
Thanks for tests ! We will think more about this model, hope to find solution fast.
Old 03-22-2008, 12:51   #12 (permalink)
Member: 204684
Thanks Meter: 21
What piout is??? it's not like MX200 as in shell is shown
Old 03-25-2008, 16:35   #13 (permalink)
Member: 130995
@Irfangk786
Please, if you still have phone on hands, try to unlock it with latest software: http://www.infinity-box.biz/download...dule_v2.15.rar
Also, please, post here phone connector photo and pinout.
Waiting for your results.
Old 04-15-2008, 19:06   #14 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
What is the pinout please ?
Old 04-15-2008, 20:43   #15 (permalink)
Member: 130995
keyboard top
connector 2x5
4: Phone Tx (RJ45 pin-3)
6: Gnd
9: Phone Rx (RJ45 pin-2)
Full support for GPRS779 and Orange Tokyo models - for VPOWER and O2 reg customers Gobi VygisToolbox 16 01-07-2009 20:29
ORANGE TOKYO pinout! gr_from Infinity-Box 1 03-22-2008 13:41
Orange Tokyo Unlock Nasmi VygisToolbox 0 02-25-2008 10:09
orange Tokyo FX1 Various 1 02-25-2008 09:53
Orange Tokyo unlock? MK5.ESCORT Various 0 02-04-2008 15:05
Page generated in 0.24394 seconds with 9 queries
