Old 05-01-2008, 13:03   #1 (permalink)
BaNgErS's Avatar
Member: 553262
Arrow Orange Tokyo unlocked with Infinty Box
Jus wanted to share my first unlock of Orange Tokyo with Infinty Box ... cable used = GPG-168 ORANGE TOKYO
Here is my log...
COM3 [VCP0] selected
Device: Orange-Tokyo
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: unlock
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8B02:8B01]...
CPU: MT6219
CPU: MT6226MA detected
chip: 0031:0941:F154
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6DF24 BCB.[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN_C8168624].rpl
identification#1 detection finished
device-id: 6DF24BCB
identification#1 protocol ver: 05
ver. sw1: DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN
ver. sw2: DS606_332B43_SW_MyWay_V4.67, DB79E937
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_67.BIN]_20080501-124222.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
detecting additional parameters...
Write: area 0/1
additional parameters detected Ok
buffer management operation active...
buffer management operation finished Ok
firmware version detected Ok
Special operation Done
Write...
Write: lock-area-4
Write: eeprom
Write Done
Finalization...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_system_log_6DF24B CB_DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_S W_MYWAY_V4_67.BIN_C8168624_20080501-124840.B0X.bin
Finished, time used: 589 sec
Remove/Install battery now !
THANKS INFINITY BOX TEAM FOR EXCELLENT WORK
The Following User Says Thank You to BaNgErS For This Useful Post:
Old 07-29-2009, 15:05   #2 (permalink)
ysmayl's Avatar
Member: 595504
Sonork: 1985.23
A try to unlock this model but "enter Network CODE" wath is the code ? a have to unlock with all 4 type
Old 07-29-2009, 19:01   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Please, post here operation logs.
Did you tried to read codes ?
Old 10-26-2009, 16:06   #4 (permalink)
ysmayl's Avatar
Member: 595504
Sonork: 1985.23
Succes unlock with MMmodule not with Chineze Miracle.
Orange Tokyo Unlock Problem rose4u86 Infinity-Box 10 11-02-2009 14:59
07 Apr 2008: Fly-V60, SkyZen-EZ100 models supported, Orange Tokyo unlock improved InfinitySupport Infinity-Box 29 04-17-2008 18:37
Orange Tokyo Unlock Nasmi VygisToolbox 0 02-25-2008 09:09
Orange Tokyo unlock? MK5.ESCORT Various 0 02-04-2008 14:05
sc c110i with infinty box not unlock arrore geepee777 Infinity-Box 8 09-28-2007 10:05
Page generated in 0.24448 seconds with 11 queries
