06-03-2016, 22:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | ORIGINAL LG G3 Stylus IMEI Repair Done 13 Sec!! Code: Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 80 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501005137585341420B161DE7B6C121 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 1501005137585341420B161DE7B6C121 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 915DCF95A631CDC8EC4A4C84A33F75F9 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : b2lds_global_com ProdModel : LG-D690 Device : b2lds AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.W10.24.p0 SECURITY : BTMAC Addr : 000046658201 WiFi MAC : 000000000000 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_SP_V11_P2_1_wg_n Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 80 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501005137585341420B161DE7B6C121 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 1501005137585341420B161DE7B6C121 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 915DCF95A631CDC8EC4A4C84A33F75F9 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [0] : 3562720683XXXX IMEI [1] : 3562720683XXXX Set IMEI [0] : 3562720689XXXX Set IMEI [1] : 3562720601XXXX Repair done! Done! Elapsed: 00:00:13 Reconnect Power/Cable! BR |
