02-25-2018, 08:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | OT-1010x issue Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B8F5A3CB68D88BC1C36D1B3E197FE252 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 38000000 DEV[0] : 4946 454C 495F 464E DEV[1] : 004F 0000 0001 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 SOC_VERIFY : 0x00 SOC Verification failed! Check cable, Battery, Connection! Boot Error! Operation Failed Elapsed: 00:02:58 Reconnect Power/Cable! Finish at : [2/24/2018 / 9:39:13 PM] Start at : [2/24/2018 / 10:01:52 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! Finish at : [2/24/2018 / 10:02:20 PM] Start at : [2/24/2018 / 10:02:44 PM] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B8F5A3CB68D88BC1C36D1B3E197FE252 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent Freeze Start at : [2/24/2018 / 10:04:52 PM] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B8F5A3CB68D88BC1C36D1B3E197FE252 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... Start at : [2/24/2018 / 10:07:11 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B8F5A3CB68D88BC1C36D1B3E197FE252 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 38000000 DEV[0] : 4946 454C 495F 464E DEV[1] : 004F 0000 0001 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 SOC_VERIFY : 0x00 SOC Verification failed! Check cable, Battery, Connection! Boot Error! Operation Failed Elapsed: 00:03:19 Reconnect Power/Cable! Finish at : [2/24/2018 / 10:10:30 PM] |
02-27-2018, 19:51 | #2 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Freeze Start at : [2/24/2018 / 10:04:52 PM] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B8F5A3CB68D88BC1C36D1B3E197FE252 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... Start at : [2/24/2018 / 10:07:11 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B8F5A3CB68D88BC1C36D1B3E197FE252 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 38000000 DEV[0] : 4946 454C 495F 464E DEV[1] : 004F 0000 0001 0000 DA_INFO : 0x00 , Ver : 0.0 , BBID : 0x00 SOC_VERIFY : 0x00 SOC Verification failed! Check cable, Battery, Connection! Boot Error! Operation Failed Elapsed: 00:03:19 Reconnect Power/Cable! Finish at : [2/24/2018 / 10:10:30 PM] |
