Old 12-25-2009, 03:59   #1 (permalink)
Registered User
Member: 972420
Sonork: manole
Thanks Meter: 134
Ot-103 alcatel can be unlock by infinity box?
Pls guide me...........................................???
Old 12-25-2009, 12:18   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
In most cases this phone can be unlocked without problems, but it may be unlock problems for phones that is locked to several network operators.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 12-25-2009, 14:27   #3 (permalink)
Registered User
Member: 972420
Sonork: manole
Thanks Meter: 134
Nice information mr infinity,100 percent unlock alcatel ot-103..................
Old 12-26-2009, 04:12   #4 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Can you give the selection of 0t 103 alcatel it is because i see here no ot 103 supported model can you post what is the same ot 103 for unlock
Old 12-26-2009, 04:14   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
I TRY TO UNLOCK BUT SAYING THIS INFINITY CAN YOU EXPLIN THIS
Read manual from support area and flash phone with special firmware !
Old 12-26-2009, 04:15   #6 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
No special firmware in support new alcatel ot 103x
Old 12-26-2009, 04:17   #7 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
HERE IN RESULT INFINITY TEM I NEED YOUR HELP
COM10 [VCP0] selected
module v2.79
Action: read codes
unlock method: read codes
Model: Aiko-17G
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:5A5E:A00C
status: 01
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: MAUI.08A.W08.36.SP1.V28.F1
Version: JRD23_NEP_08A_HW
72 byte(s) read
imei: 14C636164756C6
connection Ok
77 byte(s) read
reading data #4...
reading data #5...
error: source data size is less than expected
error: operation failed !
Finished, time used: 11 sec
Remove/Install battery now !
Old 12-26-2009, 04:19   #8 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
module v2.79
Action: read codes
Model: Aiko-17G
19200 autodetect
CPU: MT6223
status: 01
Can not initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method
Finished, time used: 55 sec
I TRY TO UNLOCK
OT 103 BUT THE PHONE IS DEAD
Old 12-26-2009, 07:54   #9 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
hi ,
always select correct model !!
you select wrong model
Faisal_Computer
The Following User Says Thank You to Faisal_Computer For This Useful Post:
Old 12-27-2009, 13:36   #10 (permalink)
Member: 130995
module v2.79
Action: read codes
Model: Aiko-17G
19200 autodetect
CPU: MT6223
status: 01
Date: 2000.00.00
Version: 1.0
72 byte(s) read
connection Ok
77 byte(s) read
reading data #4...
reading data #5...
What was the reason to use half year old software ?
How about to download and install latest updates ?
Why you select "Aiko" model if you want to unlock Alcatel ?
Please, next time THINK BEFOR MAKE SOMETHING !
Old 05-16-2010, 07:14   #11 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
module v3.38
Device: Alcatel-103X, 103A
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:5CAB:A00C
status: 01
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 17H
provider: 103X-2ATTTP1
customization: CM17CC41
customization: XM17CC41
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
max address is too big, should be recalculated: 0827D124->0826B698
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00008F3093F58A
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201005 16-111332.B0X.bin
Finished, time used: 2 min 0 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to delux_gsm For This Useful Post:
Old 05-16-2010, 11:16   #12 (permalink)
Maik_TechService's Avatar
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
broyou don't findsolution i have solution can send you an pm?
Old 05-16-2010, 11:18   #13 (permalink)
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
Sorry for my writting send me pm i shown you solution
or team i have permittion to post unlock method or by pm ?
Old 05-16-2010, 12:31   #14 (permalink)
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
hehehehe bro lilong_lee refuseto send mp pm cryyyyyyyyyyyyyyyyyyyyyyy go on pm i will showm you bro hosting is great family Team y or n?
you have this model now? in your hand ?
Old 05-16-2010, 12:44   #15 (permalink)
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
lilong_lee chech you pm send you solution ok
Alcatel C552a can be unlocked by PB2? Panthereitor PolarBox 3 7 01-29-2008 23:31
Alcatel c552 can be unlocked by FGBE?? Panthereitor FuriousGold 4 01-21-2008 22:52
6680i (I-mode) can be unlocked by mt-box lite?? etersat MT-BOX 11 12-05-2007 19:36
J120 i can not be unlock with infinity box with last update leroi Infinity-Box 3 11-09-2007 11:12
Which phones can be unlocked by Multi-Box? justmegt Multi-Box 3 09-25-2007 19:55
Page generated in 0.26771 seconds with 9 queries
